Thread: Solar Panels - Use Filter Pump or Separate
    I currently run a separate pump for my solar panels, an old pool intex pump, connected through an over the side PVC setup homebrew. It works well, but looks like **** and it's jsut one more thing for the kids to bump into.
    I'm wondering if I should just use the setup that they recommend, running the filter pump water through them instead? Less plumbing, can control with one timer, and it'll look nicer.
    Suggestions? My other option would be to add new bulkhead fittings for the plumbing and do it that way. It's an 18' 52" intex metal frame pool.
    Thanks!
    Richard
    Temecula, CA
    28,000 Gal. In-Ground plaster and tile, Total Control AutoPilot with SC-60 SWG and PH control, Pentair EasyTouch 8, EasyTouch Wireless Remote, Intelliflo VS+SVRS pump, Intellibrite lighting, Pentair Quad 100, Solar heating, Pentair Mastertemp 400 Gas Heater, The Pool Cleaner 4x, Aquabot Turbo T2 Robotic Cleaner, Water feature spillover from SPA.
    Aug 2009
    NW Ohio
    3
    Re: Solar Panels - Use Filter Pump or Separate
    I run mine on the same pump and don't think I have any issues with it. I have ball valves on the supply and return so I can isolate the panels if I had a leak or something. I ran 1 1/2" pvc underground to the panels to feed them and it works fine for me.
    Joe
    13,500 gal. 24' AG vinyl with bottom drain, Hayward S180T sand filter , 1 hp Power-Flo lx pump
    TF-100 test kit, well water, 4x20 solar panel.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Having a solar pump is just too expensive (electricity use). The only time they are needed really is in commercial applications. Where flow rates must be maintained.
    Factory Warranty Station for:
    Thanks guys!
    The pump I'm using is from a little 12' intex blow up pool, so it doesn't suck much power. I would, however, prefer to simplify everything a bit, so I think when I hook it all back up, it'll just run through the main pump.
    Richard
    Temecula, CA
    Aug 2009
    Gilbert, AZ
    12
    It seems like much of the energy required to push the water to the roof is regained when it goes back down. Think of moving a rope over a pulley with a weight on each end. What required energy is most likely the friction of pushing water through all the small tubes, which I think normal pool pump should be able to handle no problem.
    mas985's Avatar
    Pleasanton, CA
    11,741
    Are your panels located on the roof? If so, that pump may not have enough head to prime the panels but you can always give it a try.
    Mark
