Results 1 to 7 of 7
Thread: right size pump?
    right size pump?
    is a 1.5 hp pump too much for my pool? i think it maybe based on info on this website? if it is too large for my pool, what kind of problems will it cause? do i need a new pump? also my pump is a single speed
    24 ft. 52 in. deep above ground
    hayward sand filter
    new pool owner/new bbb believer
    22,542
    Re: right size pump?
    We have a 1-1/2 hp pump on our pool and it works great. It could stand to be either a 2-speed or a 1 hp but the 1-1/2 hp works great. Besides it only takes 3.5 hrs to get a turnover so I get more than 2 a day running 8 hours. The biggest thing it does is uses more power but I compensate by running it less.
    30,403
    If it is a full-rated 1.5 hp (probably not) then it is probably too big for your filter. What is your normal operating psi?
    pool has been up 2.5 months and psi started clean 15 psi and has only gotten to 16 psi since first day.
    hayward sand filter
    30,403
    That's not bad. I suspect you have an uprated 1.5 hp pump which, in reality is around a 1hp pump.
    Anyway, the important thing is your pump appears to match your filter pretty well and you should have no problems. Generally a .75 full-rated pump is adequate for your size pool but the filter/pump match is a more important than the precise hp.
    I think you're in good shape.
    thanks for fast response. tfp has been a pleasure to deal with. my pool has been almost perfect since day one.
    hayward sand filter
    dmanb2b's Avatar
    Apr 2009
    NY
    3,730
    I run a 0.5hp full rated with no problems...most energy efficient for a typical abg pool IMHO...the problem with a 1.5hp is not that it won't do the job, it that 1.5 inch pipe doesn't allow it to pump at full capacity, therfore wasting energy.
