Thread: I need help with Valves and Digital Timer
    I am trying to replace the valves to my system,,,all of the valves handles have broken off, plastic got week after 4 year of sun, rain...etc. Now I have to replace them and after calling to get an estimate, they want 900.00 to get those 5 valves and the digital timer, which I have found online for 150.00.....Can anyone give me some hints...it doesnt look that difficult to do
    DIY Fiberglass Pool under construction
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: I need help with Valves and Digital Timer
    A picture would help for the valves. Having to replace that many valves you'll probably just want to remove fairly large sections of plumbing, unless you either have room for a coupling next to every valve or the replacement valves you're using are about 3" longer than the old ones.
    As for the timer, it'll require some minor electrical work. If you're not comfortable with that then buying the timer and having an electrician install it would be a good move.
    here are the pictures...I was able to bypass the timer and identify what was wrong with it, no I have to work on the valves
