Thread: Auto chlorine feeder or a floater for low chlorine levels?
    flyboy320's Avatar
    Jul 2009
    Burlington, Ontario, Canada
    216
    We are installing a Delta UV system in our pool, and I understand that this should help reduce the amount of chlorine needed over a "traditional" pool. If only a small amount (what ever that amount is!) of chlorine is need in the pool, what would be the better way to add it? The builder is installing a Hayward CL-220, and I understand many people feel this is not the best choice, but I figure I will let him install it, and then I can decide later to use it or not. Would this be the best solution, or would another way, like a floater style work better?
    10K gal IG, vinyl, 1 HP Jandy Stealth pump, Jandy CS cartridge filter, Delta UV system, Hasa Liquidator
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Auto chlorine feeder or a floater for low chlorine levels?
    Floaters add chlorine at a pretty slow rate. Go with the chlorinator, or better yet, forget the UV and the chlorinator and use a salt water chlorine generator.
    flyboy320's Avatar
    Jul 2009
    216
    Quote Originally Posted by JohnT
    Went though that debate before we started the project, and decided there is no "ideal" solution. Didn't like the problems some people experience with SWG (the stones deteriorating around the pools edge, or heaters rusting out when not grounded properly, etc.). UV is not perfect either, but it's UV we decided on, so still lots of reading to do regarding pool chemistry!
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    chlorinator over floater.
    flyboy320's Avatar
    Jul 2009
    216
    Quote Originally Posted by frustratedpoolmom
    OK, thanks, much appreciated...
