Thread: Solar plumbing - which way?
    Vero Beach, FL
    462
    Which is best? Top diagram, Bottom Diagram, Arrows reversed? Or does it really not matter?[attachment=0:34tblcrt]solar.gif[/attachment:34tblcrt]
    25' x 13' Roman, 12000 gal IGP, Plaster, with 500 gal Spa
    SWG, 1 HP Max Flo Pump, C-900 cartridge filter
    Solar heat
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Solar plumbing - which way?
    They are basically the same and should perform about the same. If forced to choose and you are installing this on a roof then I would probably go with the second one only because the vacuum release valve is on the shortest piece of supply pipe. It will close a bit quicker and will allow you to run at slightly lower pump speeds (i.e. lower pressure) if you have a variable speed pump. But even then it will be a very small difference.
    Note too, that the return pipe could come back over the top if that is more convienent. Just don't have a local high spot or it might not full drain.
    Mark
