Thread: How much sand in the filter?
    Jerry's Avatar
    Aug 2009
    New Orleans
    48
    I am cleaning out the snad with a hose as recommeded onanother thread....It appears that I have lost sand...it's about half full.
    Sould I add sand?
    10,000 Gal. Inground Plaster Lap Pool
    Sand Filter
    New Orleans, LA
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: How much sand in the filter?
    yes you should add sand. I use 6-8 inches from the top of the filter opening as a general rule of thumb. What brand/model filter do you have? If you know this you may be able to look up the owner's manual online.
    Jerry's Avatar
    Aug 2009
    New Orleans
    48
    Quote Originally Posted by dmanb2b
    It's a Hayward and the label says 200 lbs.....I think I remember that being about 12" from the top.
    I flushed the sand pretty well until the water was clear.....the sand is 3 years old.
    Should I add or replace it all?
    Sand Filter
    New Orleans, LA
    Mar 2007
    Coastalish 'down easter'
    4,160
    ~1/2 way up a Hayward filter is normal (the ones that have a top and bottom, should have the sand ~ at the seam)
    Luv& Luk
    -Ted
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    even at 10-12 inches you should be fine. IMHO sand should be flushed via backwashing...so I'm not quite sure why you are manually rinsing your sand, if I'm understanding correctly?
    Given it's 3 years old replacing 200lbs will only cost you $10-$15...your choice, but IMO not needed. Good luck with the project.
    Jerry's Avatar
    Aug 2009
    New Orleans
    48
    As suggested in this post:
    http://www.troublefreepool.com/liqui...ner-t9691.html
    A lot of dirty brown water, small particles of debris and oily, green bubbles came out....took about a half hour.
    Sand Filter
    New Orleans, LA
