Thread: Gaskets for return jets?
    Jerry's Avatar
    Aug 2009
    New Orleans
    48
    Today, after repairing the broken pvc pipe to one of my returns, I tested the system with the water well below the jets.
    3 out of 4 of the eyeball plates had a lot of water spraying around the outside of the disc....these are Swimquip round eyeball plates held on with 4 screws each.
    Should there be a gasket undet the cover plate?
    10,000 Gal. Inground Plaster Lap Pool
    Sand Filter
    New Orleans, LA
    JoshU's Avatar
    New Orleans, LA
    543
    Re: Gaskets for return jets?
    No, there shouldn't be a gasket or o-ring.
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
