Thread: Pool and Spa Warehouse
    rdkll's Avatar
    Jul 2007
    Huntsville, AL
    Well I just pulled the trigger and got an Aquabot Turbo T from Paul. I should be getting it in a few days. In fact, I am probably wait to turn my green pool sparkly until I can get after it with the robot. Actually I will probably get started and hopefully most everything in the pool will be dead and the 'bot can sweep it up.
    Paul is first class and we are fortunate to have Pool and Spa warehous onboard as a sponsor.
    1) The size of your pool in gallons = 33,500 16x32x40 L
    2) The type filter you have = 300lb Sand
    3) IG
    4) If it's IG, vinyl liner
    5) pump is 1.5hp
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    Re: Pool and Spa Warehouse
    Quote Originally Posted by rdkll
    What's the news on the Turbo T? The reviews I've read previously indicated that it tended to get tangled up on its own power supply cord. Have you found this to be the case? Thanks.
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
