Thread: First time testing water with Leslie's DPT test kit
    Aug 2009
    Central New Jersey
    14
    Hi! Everyone, this is my first time testing the water with this kit, I notice the TA is very high, i don't know if i tested correctly. Water temperature is 82, water is crystal clear. pool size 10600 above ground. Using bleach.Here are the readings;
    ph 7.4
    cya 40ppm
    TA 450ppm
    FC 5
    TC 5
    TC 0
    I need help understand this readings,
    Thank you.
    P.S My water has never looked this good until now
    12,600 gallons
    Cartrige filter
    1 hp pump
    24x18 Above Ground Oval
    Re: First time testing water with Leslie's DPT test kit
    You should wipe the tip of the titration reagent bottle with a damp tissue and do the TA test again, wiping the tip every five to ten drops. Sometimes the dropper tip can build up a static charge that causes the drops to be smaller than they should be, which can cause very high, incorrect, readings.
    A TA of 450 is very high and could lead to calcium scaling. Hopefully it is just a testing error.
    Aug 2009
    Central New Jersey
    14
    Thanks Jason, I did that and is now 120.
    12,600 gallons
    Cartrige filter
    1 hp pump
    So, with that resolved, it sure looks like your water tests to be perfect.
    Water test -- check
    Water clarity -- check
    Sparklyness -- check (?)
    That looks like a TroubleFree Pool!
