Thread: Time to upgrade filter system. What size pump and filter.
    We have an 18 by 38 oval with a 7.5 feet deep end. I'd estimate the total volume to be around 24,000 gallons. It's time to replace the old Doughboy pump and filter with something new. Tired of the pump noise and occasional sand in the pool. I'm thinking of adding a second return line to help with circulation in shallow end behind cake steps, where flow seems to be lacking. That line would be 1 1/2 inch and run about 40 or 45 feet. The second return would be in the opposite "corner" of current return, which is in the deep end.
    Any suggestions on pump and filter size. Make and model? New vs. used? Is the second return line going to help with circulation, or is that just overkill?
    By the way, we bought the pool used and we are nearing the end of our first season. I'm guessing the equipment to be about 10 to 12 years old.
    Any suggestions would be appreciated.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Time to upgrade filter system. What size pump and filter.
    I would suggest a 1.5 hp two-speed, pentair whisperflow and at a minimum a 300lb sand filter like the hayward S244T maybe even a little larger.
    You have a fairly large pool so the two returns would definately help. On the filter, you can never really go too large.
    It sound like you've had some bad experience with sand, but is likely to be due to a bad multiport valve. I'd much rather have sand in my pool why something goes wrong than DE, but that just my opinion. I prefer sand due to the ease of maintenance. Good luck, other will be along soon with their input as well
    frankthailand's Avatar
    Apr 2008
    Thailand
    152
    I agree with dmanb2b good combo, personal experiance tells me to suggest that you could get a bigger filter if you can afford it
    Happy swims
    Frank
    Hello all from the land of smiles. Thailand. 5mx9mx1.5 63000L 16300 gall, pebbletex,
    pentair 1hp whisperflow, tagelus TA60 SF, swg monarch esc24 {a bit small for the tropics} 3 returns, 1 skimmer, 2 astral 100watt lights. Planned and built by me
    an AUSSIE expat living thailand for 18 years.
