Results 1 to 9 of 9
Thread: TA Readings
    H2O_Keeper's Avatar
    Nov 2008
    SW Indiana
    140
    TA Readings
    I have been working on lowering my TA from 140 to 80 and am confused where I am at. I realize I still need to work it down some more. This is with the TFTestkit.
    On the 8th drop after a good swirl it is still a solid green. On the 9th drop the solution turns this COLOR and on the tenth it looks closer to this COLOR. So is my TA 90 or 100?
    21K Gal, IG, Vinyl, Bleach-Borax-Baking Soda, 3/4HP Hayward pump, Hayward sand filter, 200,000BTU Heater, TF100 Testkit
    "All that we are arises with our thoughts." - Buddha
    “When fate hands you a lemon, make lemonade.” - Dale Carnegie
    Bob_Funk's Avatar
    May 2009
    Seattle-It really rains all the time
    113
    Re: TA Readings
    As I understand it,
    You keep adding drops until there is no more color change-do not count the last drop in your total.
    Does that make sense?
    Bob
    I consider myself very lucky I found this site before the pool store found me-pool owner since Nov 2008- Stunningly clear 17,000 gal fiberglass pool, thanks to this site, installed in 1982-24" 3.1sq. ft sta-rite sand filter, 1 hp - 2 speed wisperflo pump-WFDS-4
    Re: TA Readings
    Quote Originally Posted by Bob_Funk
    As I understand it,
    Bob
    Which is to say, the 9th drop changed color so you count that, the 10th drop changed color so you count that. But what happened with the 11th drop (that you did not do) IF it did not change color further, you don't count it, so you would have stopped at 10 drops. If it did change color, you count it and keep going.
    So, I'd say you are at 100, or even more, but probably just 100.
    Jan 2009
    Cupertino, CA
    1,966
    Re: TA Readings
    Ditto to what anona said, except I think your TA is more likely 110-120. When I run the TA test I get a final color that's more like THIS. Keep doing drops until the color doesn't change any more; the exact color is not the point.
    --paulr
    BBB "Intermediate Swimmer"
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: TA Readings
    Um, I think your TA is fine where it is (about 100).
    Unless you have some source of aeration, like an attached spa, waterfall, etc. or you have an SWG, a TA of 140 is ok and not worth the hassle of trying to lower it... I had a TA of 120 for 2 years and my ph never budged.....
    H2O_Keeper's Avatar
    Nov 2008
    SW Indiana
    140
    Re: TA Readings
    Thanks all, I was confused about the term red in the directions. Did not know if any form of red was okay or what. Now I know its no further movement of a red color.
    I will leave it alone where it is and see if I am locked in at 100 or possibly 110 the next time I check. I had my TA at 90 the beginning of the season and it barely moved PH in over a month. And now it was up to 140 and I found readings drifting to 7.8 about every two weeks (I leave alone till I get a solid 7.8 maintaining 7.5). Assuming the recent MA adds were necessary due to the higher TA. I dont have waterfalls or anything of the sort. We have had a lot of rain this year, does that raise TA?
    Jan 2009
    Cupertino, CA
    1,966
    Re: TA Readings
    Quote Originally Posted by H2O_Keeper
    Rain typically has no TA; you can put out a cup next time there's a big rain and collect enough to test it yourself and be sure.
    --paulr
    H2O_Keeper's Avatar
    Nov 2008
    SW Indiana
    140
    Re: TA Readings
    Guess I didn't word the question correctly. I realize the rain water may not have any TA in it, but is there aeration created by the rain that raises the pool's TA?
    Re: TA Readings
    Rain, and other sources of aeration, often raise the PH, but have no effect on the TA.
