Results 1 to 8 of 8
Thread: Do I need to shock
    Aug 2009
    Pearland, TX
    10
    Do I need to shock
    We had rain this weekend and my pool is cloudy, blue but cloudy. Thursday I was in the pool which stirred up some sediment (I think dead algea) on the bottom of the pool. I also adjusted my return jet to point just under the water surface (previously it had been pointed further up and stired the surface of the water quite a bit).
    Here are the water test numbers
    FC = 17
    CC < .5
    Ph = 8.0
    TA = 220
    CH = 220
    CYA = 140
    I know that the CYA level is really high (but is better than the 220 it was about 2 weeks ago). I need to lower the Ph with, I think, will also lower the TA.
    Question: Do I need to shock to get the water to clear up? The FC is holding and the CC is low.
    Frank Jurgens
    21' AG, 11000 Gal Vinyl Liner
    Sand Filter
    Re: Do I need to shock
    Well, checking the CYA chart it appears that since at CYA 30 shock level is 12 and at CYA 60 it is 24, then apparently we can just double the values for CYA 70 to get a shock level for CYA 140 of 56. Wow.
    So, you definately need to increase chlorine levels and is there a way to clear out the sediment/dead algae? Can you vac to waste?
    30,404
    Your pool will forever give you problems with algae until you make the comittment to lower your CYA.
    You don't say how you chlorinate so I assume you don't have an SWG. Your CYA needs to be 60 at the most and your pool will become far easier to manage.
    Take your pH down to 7.5 or so.
    EDIT: Dmanb2b makes a good point below that I missed......disregard your pH test until chlorine drops below 10ppm
    dmanb2b's Avatar
    Apr 2009
    NY
    3,731
    to adds to daves comments, you really should address your CYA level...PH readings are know to be inaccurate (false high reading) when FC levels are 10ppm or above.
    Aug 2009
    Pearland, TX
    10
    I have already dumped about 1/3 of my water to get the CYA down to 140. I still need to do at least another 1/3 water change.
    I use bleach to add chlorine. I just started the BBB method about 2 week ago and I just got my test kit last week. The pool is looking better than it has in a long time.
    Another question: In general, do you need to shock after it rains, or do you only shock when there is a problem (like cloudy water to high CC)?
    Frank Jurgens
    Sand Filter
    Quote Originally Posted by fdjurgens
    In general, you only shock when there is a problem.
    In some cases you may choose to raise the FC level to head off a problem, like when you are expecting particularly heavy rains or maybe a big pool party.
    In our pool, I know that it can handle a 1 inch rain easily. Most of the time we get wind with the rains and I get a lot of pine needles in the pool so I take care to clean out the skimmers and Polaris promptly afterward. I am testing the pool at least every other day right now, so after the Polaris runs and the skimmers do their thing after a big rain I might test to see if I needed to add more chlorine, kinda just depends on how the pool looks. Dirt is worse than leaves I think and in a big storm I do get dirt washed in sometimes.
    Now if there was a Tropical Storm with forcasts of serious rain, 4 or 8 or 10 inches of rain I probably would bump the pool up to the top of the FC range or even a bit higher, maybe even drain down the pool a bit just so I don't have to do it in the middle of the storm. For me that is as much worrying about loss of power as anything else, better to have a bit extra in the pool if it may be offline for a few hours.
    But I haven't shocked my pool in a long time.
    30,404
    If you want to get down into a range you can manage handily, you need to do a little more than 1/2.
    Aug 2009
    Pearland, TX
    10
    I am going to get the CYA level down, I just don't have a full day to mess with my pool right now. That is what it will take to drain and fill the pool. I don't want to leave my pool only half full and risk the sun damaging the exposed liner.
    Frank Jurgens
    Sand Filter
