Results 1 to 11 of 11
Thread: Edging ideas for pool decking
    Okay gang, I need any input from you wonderful folks.
    I have been fighting a constant and almost losing battle all summer long with these dang grass clippings that end up in the pool. I'm tired of fighting with the step son and I am tired of fighting with the pool.
    So, what is the best way to put some kind of edging on the concrete where the deck meets the grass? The wifey doesn't want to get rid of the grass so
    I am left with little alternatives. How do you edge your concrete decks that meet grass?
    Thanks in advance!
    13,100 gal (?) IG Plaster Pool, Rectangular (30 feet long, 11 feet wide at 3 feet deep shallow end, 14 feet wide at 6 feet deep end.)
    Pentair Challenger 1hp 2 speed hardwired pump
    Triton II T60 sand filter
    P153 Intermatic digital timer control
    8 gal Liquidator with 3/8" upgrade
    Re: Edging ideas for pool decking
    Most mowers throw primarily out of just one side. Is the step-son mowing such that the throwing side is never facing the pool? I know it seems obvious, but kids, especially if they'd like to get out of something, often will not take that extra step that keeps it clean.
    Otherwise, you can either put up something tall enough to block the grass clippings, or wide enough to catch most of them while at the same time removing the grass a bit further away. So, that would be a narrow strip of bed, with some plant or shrub that will grow low enough to the ground to block effectively.
    My house has the pool decking surrounded by landscaping. So, no one has much chance to get into fresh clipped grass nor can grass be easily blown into the pool area. At the back of the house is a wood deck that connects to the pool decking. On one side as you leave the pool area to go towards the side yard and pool equipment the small opening that leads to the grass has a few large boulders that serve as stepping stones between grass and decking. On the other side, after you pass through the iron gate to that part of the yard, you are on a flagstone walkway the whole way to the screen porch on that far side. So no one ever touches grass on the way to the pool.
    22,550
    My son-in-law mowss our lawn and I have him cut in a counter-clockwise direction any time he's anywhere around the pool. We no longer get grass clippings in the pool. I'm sure one of these days the wind will be blowing 90 to nothing and I'll have some to clean out but it's much better since he's mowing that way.
    Mar 2007
    Ontario
    211
    Maybe its time to buy a lawn mower with a rear bagger!
    16x32 inground vinyl 8' deep end
    1hp Northstar Pump, 20" Sand Filter
    6ft Double Lounge, 2 Aqua Lamps w/remote
    216sqft Sungrabber Panels (9- 2'x12') a little undersized
    May 2009
    Rocket Town, AL
    49
    This may sound crazy, but I have the wife run the blower while I edge the deck. She blows, I cut at the same time.
    (insert bad jokes here)
    18x36 In-ground Vinyl, 24,000 gallons.
    Sand Filter, 1hp Hayward.
    SWG
    Polaris 280
    Quote Originally Posted by haybird
    It has a bagger! Still I get lawn clippings.
    Running the blower sounds like the easiest way yet.
    Jul 2007
    Suwanee, GA
    528
    I've got about 3' of landscaping around the pool where the grass is level with the pool. Where the grass does meet the deck there is a raised wall, while the grass does get all over the deck, it does not get into the pool. I have a rear bagging or mulching mower and it is impossible to keep the grass off the deck where they do meet.
    This is an older pic when we first put the plants in, the planter does catch a lot of junk from making the pool.
    Gary
    21k gal SW, IG Gunite PebbleSheen, 1HP Jandy, Jandy 340 filter, Polaris 280, 17' fiberglass slide w/ 2HP pump.
    Quote Originally Posted by crabboy
    Okay, okay, now we are cooking with gas! How high is this raised wall?? I can handle grass on the deck.
    Jul 2007
    Suwanee, GA
    528
    about knee high, only part of the deep end.
    Gary
    N.E. South Carolina
    68
    Don't do what we did.
    We have about 3 feet of landscaping around our pool deck, and mulched with PEA GRAVEL. I hate that stuff. It ends up on the pool deck and we step on it (Ouch!) or it ends up in the pool. And we have a liner! I wish we had spent the extra money for the bigger rocks that would stay put.
    Judy
    Designated "pool girl" for 18' x 40' in-ground vinyl pool built in 2006
    Jul 2008
    Flintstone, GA USA
    112
    Other solution is cut the grass youself and find something else for the step son to do.
    My grass goes completely up to the concrete decking and I always prefer to not mulch my grass because of the lumps that are sometimes left. I like to cut it and let it blow the grass evenly on the lawn. ALWAYS cut so the grass is blowing away from the pool. Then what little clipping that might blow onto your deck should be immediately blown off with a gas blower.
    The bagging situation sounds great but I always like to recycle my clippings on the lawn.
    Mow regularly at least once a week. I mow twice. You will have less clippings that way to worry about.
    Tom
    Tom
    18 x 36 Grecian Polynesian Fiberglass Walls with Concrete bottom - 3 ft to 9 1/2 ft. deep -
    Hayward Variable Speed Super Pump SP2600VS 1 1/2 True HP,Hayward sand filter S200, and Hayward auto clorinator. Hayward 250,000 natural gas heater. PoolKeeper automatic water leveler. Loop Loc Ultra Solid Safety Cover. Hayward Color Logic 12 volt light. Dual Pool Deck Jets.
    Polaris 380 auto cleaner. Trouble Free Test Kit TF-100.
