Thread: Pool filter won't stay on
    My husband backwashed the system this morning and now he can't get the filter to stay on. The filter fills up with water, it clicks on and then the water empties out. We have the Aqua Logic and Hayward system salt pool
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Pool filter won't stay on
    Sounds like the pump is sucking air from someplace. Check all the connections and possible points that air can enter the system. Make sure the water level is up high enough in the skimmer.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    Is the breaker tripping? Or do you know what is turning off?
    Backwashing shouldn't effect the pump's operation, unless an electrical connection got soaked in the process.
    Were any suction valves closed and not reopened?
    Any chance of getting a pic of your pump and filter?
    Trying hard to help you, but need more info to point you in the right direction
    Luv& Luk
    -Ted
