Thread: Vacation prep??
    Vacation prep??
    Just got my pool up a two weeks ago and the BBB method is going great. I'll be going away for 9 days.... What should I do about the pool? Is there a pre-vacation treatment that I should apply to reduce problems?
    Details:
    12X24 AG (7700 gal)
    sand filter
    pH 7.5
    TA 80
    FC 3-4
    CYA 40
    12X24 Oval
    sand filter
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Re: Vacation prep??
    There are two possibilities you can do that I have seen discussed here ...
    1) Ask someone (neighbor or friend) to watch the pool and add chemicals as needed while you are away.
    2)If you have a pool cover, you can raise your FC to shock level or a little bit higher right before you leave,put the cover on and hope for the best. Since you know how to care for your pool, if you do get and algae bloom while your away you can get it back under control in no time.
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    Jan 2009
    Cupertino, CA
    1,966
    Re: Vacation prep??
    3) Put two 3" trichlor pucks in a floater. In my pool they last > 1 week. For occasional vacation use the extra CYA isn't worth worrying about.
    If you go with #1, I wouldn't put them through a test training routine (unless they also own a pool), just tell them add this many cups of bleach every day (or every other day, or whatever).
    --paulr
    BBB "Intermediate Swimmer"
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Vacation prep??
    I've done as Tiz suggested.
    Three annual 9,10, and 11 days. Each time I shocked, and covered. Left pump running. Came home each time to a FC residual. The cover is what makes the difference, this last June I only lost 50% of my FC in 10 days - the dark blue cover reall cuts down on uv loss.
