Thread: Heater not controlled by Jandy Aqualink...
    So,
    My friend's heater's been worked on a lot over the years, and he tells me it's been controlled by his Jandy Aqualink. It's a Laars LX - which the manual clearly says it can't be controlled by the Aqualink. I looked at the heater tonight, and there's a control wire coming out of it connector - wired to a terminal block. Reading the installation manual, it says that these should hook up to a low-voltage heater control (from a manual time-clock).
    Well, the Aqualink control board has a "low voltage heater" control on it.
    Will this control the on-off of the heater?
    - Jeff
    ~45Kg Pool with attached Spa, NSP-72 DE, Minmax 400 Heater, Tahoe Blue Pebbletech, Jandy SWG via Aqualink RS-8, The Pool Cleaner (black)
    Pumps: X3 Hybrid Pump (switches to SPA), 2HP Spa (additional, when SPA is on), and a 1HP For Waterfall
    8, 4x12 Solar Panels on the roof of the pool-house (~12' up)
    CAPTAIN JAMES T. KIRK: "I'M SORRY. I CAN'T HEAR YOU OVER THE SOUND OF HOW AWESOME I AM" (Thanks to TFP!)
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Re: Heater not controlled by Jandy Aqualink...
    Is that connection labeled for a fireman's switch by any chance? Raypak, another heater manufacture, would have two connections. One for the automation, and one for a fireman's switch (for time clocks). The fireman's switch would cut off the heater once it was opened, but would not close again till the power went off, then came back on. So the complaint would be the heater brought the pool up to temp, then it wouldn't come back on to hold the temp (at set point) till the next morning (when the pump came back on). And this was the heater working properly, just hooked up to the wrong terminal.
    Factory Warranty Station for:
    Feb 2008
    Dallas, TX
    60
    The Jandy equipment (Aqualink) uses the Fireman's Switch to disable the heater when heating is not needed.
    Notice that while the pump is running and the heater is off that the "Pressure Switch" LED on the heater is lit. The first time I saw this I thought there was a problem. Nope. That's just how the system is wired.
    31000 Gal IG L-shape w/ spa, Riversand finish (PebbleSheen clone)
    Jandy 60 sq ft DE, 2.5 HP (uprated) Stealth pump, Polaris 280 w/ booster, Jandy PDA PS4 controller
    Well, I think its hooked up that way - but I didn't have the circuit diagram with me yesterday - this is on fig 10/11 of the manual (says it goes to the limit switches, but if I look at fig 8 - it indeed shows the circuit/terminal block on the low pressure switch).
    I'll look at it this afternoon (this time, with the manual) and let you know - thanks for the help!
    - Jeff
    That was it...
    I'm so amazed at the "work" the last guy did on my friend's heater - he had the limit switches switched around 135 in 150 spot and vice-versa), and set the heater up so that whenever the pool pump came on, so did the heater (regardless of temp, or spa/pool mode). The limit switches burned out - likely because the heater never had a cool-down (it would just turn off with the pump), and he had the fireman's switch all wired screwy:
    Two terminal bar:
    Bar 1 Pressure-circuit = pressure circuit (this completed the circuit for the pressure circuit)
    Bar 2 LV control wire to Jandy = wire to jandy, not connected to anything inside the Aqualink controller - just hanging there!
    Correct config
    Bar 1 Pressure-circuit = LV switch wire to Jandy (Red)
    Bar 2 Pressure-circuit = LV switch wire to Jandy (Black).
    Geeeze...
    Thanks for the help.
    - Jeff
