- May 3, 2007
- 16,975
- Plaster
- Hayward Aqua Rite (T-15)
As some of you know, I have managed to create a reasonable model of swimming pool plumbing that for the most part seems to be fairly accurate. However, I have modeled less than a half dozen pools so far so I do not have enough information to tell me the overall accuracy. My object has been to predict head loss from a limited set of information that is easily obtainable by most pool owners. Return head loss is fairly easy to come up with based upon the filter PSI but without a suction guage, suction head loss is a bit of a guess. To improve the model, I am asking for some help from the TFP forum. If you are willing to help, please provide the following:
Type of pool: In ground or above ground and equipment list (i.e with or without heater, solar, spa, water features, etc.)
Pump Model: Include HP, service factor (usually lableled SF
Filter PSI without solar (assuming guage is working properly and filter clean)
Filter PSI with solar (if available)
Suction Measurement with and without solar (optional: only if you can)
Flow Meter Measurement with and without solar (optional: only if you can)
Suction Plumbing Description:
Return Plumbing Description:
Once I have collected enough information and can verify the model assumptions, I will be happy to share the results.
Thanks for your help.
- Pipe diameter
Pipe length pad to closest skimmer/drain
Number of pipe runs pool to pad
- Pipe diameter
Pipe length pad to closest return
