Results 1 to 10 of 10
Thread: Wood and Block pool
    morrodds's Avatar
    Aug 2009
    Leona Valley, CA
    10
    Wood and Block pool
    Greetings,
    In 2002 we set up an AG rectangular pool on the South slope in front of our house. A 3' high block wall was built into the slope to make a flat area 15 X 34. Later a composite deck around 2 and a half sides. Here's what it looked like the week before Christmas. Note my sons bare footprints.
    The pool had its problems and required replacement. I studied various options and designed a pool to fit the existing deck and walls. Plans and books were purchased from DEB Design, Homebuilt Pools and Sunland Owner-built pools. I also investigated a Vanishing edge pool - beyond me, I decided. The final design uses pressure treated (PT) wood framing 4' high along the South and West walls. The Other walls were extended 1' above the block and all 4 walls were covered with 1/2" PT plywood.
    Here's the old pool and other mess before demo.
    Here's a view of the South wall posts being set in concrete. PT 4x4s 6 feet long are set in 2' of concrete with a 34' 12"X12" bond beam connecting them. The initial deep end hole is seen here also.
    The West and North walls are shown before the vertical extension and end wall framing are finished. Note the South wall posts.
    Here is the East wall with extension framing and skimmer hole, Some of the framing for the South wall is in.
    The wall framing is complete with the plywood sheathing. SS screws used throughout. PT wood is rated for contact with soil.
    Here's the West view with returns and vacuum port visible. The Solar cover will reside under the far deck and an extension to the left. 46" shallow - 6'6" deep end.
    Last Saturday the perlite/concrete bottom was placed. White foam on the walls. 2X8s with beveled edges in the corners. Note the composite decking on the pool walls.
    Liner in and filling with water - Saturday afternoon.
    Sunday - full of water and a happy kid.
    The concrete was poured on July 3rd and liner placed August 15th. Weekends and evenings well spent. Soon I'll be able to stand up straight again I contracted the concrete work - everything else was on me. Two ladders, one on each end of the pool will go in tomorrow.
    Thanx to all for your help and suggestions on the chemistry.
    Regards, Martin
    17k gal., sorta IG vinyl, 1.5 hp pump, 21" sand filter, Shark robotic cleaner.
    Arizona
    924
    Re: Wood and Block pool
    Very cool pictorial of your pool demo and rebuild. It never ceases to amaze me at the various methods to build a pool.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    30,414
    Very nice work. I also ordered the DEB design book. While I built something quite different than their suggestions, it gave me food for thought.
    Like you, I probably continue to walk a little humped over from the physical work but, unlike you, it took me almost 3 years to complete my whole project. You had a good plan and worked it well.
    Nice looking pool.
    morrodds's Avatar
    Aug 2009
    Leona Valley, CA
    10
    Thanx for compliments.
    Buggs - This one was interesting since I wanted to blend it into the existing deck and retaining walls, hence the hybrid design.
    Dave S. - I used the DEB book for the wood wall, HOMEBUILT Pools book addressed the block walls, later I stumbled across the SunLand book which addresses both. Your pool is a MONSTER and beautiful! I especially like the curved corners and steps. You must have alot of friends to be able to fill it with bodies.
    Thanx again, Martin
    30,414
    Martin,
    As I was learning, I really wanted to use the PT plywood walls but I was afraid I couldn't get them smooth and even enough for the 1/4" foam to take out all the bumps.
    How did you go about keeping all the edges and joints even? Did you fill in with any "spackle" (for lack of a better description) type material?
    How far apart are the up-rights?
    Are they braced in-between with extra structure or was the plywood sufficient.
    Thank you for the nice words on my pool.
    Casey's Avatar
    SW PA
    10,427
    Your pool build is awesome! Congratulations! I will be a hump back in a couple short years when I attempt to do my inground pool build pretty much on my own!
    morrodds's Avatar
    Aug 2009
    Leona Valley, CA
    10
    Dave,
    The uprights are on 4' spacing. They are faced with 2X6s laid flat against them:
    The plywood was screwed to them with 2" SS screws on ~1' spacing. The butt joints were sealed with Gorilla tape before the foam was applied. No 'spackle' - one builder used Bond-O in the defects. The pattern on the vinyl hides a multitude of sins. Actually I don't see surface imperfections. The most noticeable defect is the warped 2X8s on the top cap.
    The plywood was extended down over the block. Seemed easier and quicker than trying to smooth it all. I was careful to line up the framing so laying the plywood went pretty slick. I used a vertical receiver butted against the composite decking with a urethane caulk and galv. screws - this covered any other irregularities.
    Casey - thanx and good luck on your future project.
    Later, Martin
    Great Pool! It inspired me to build one similar and I'm midway through it right now. I hope to complete it in the next couple of weeks- Finally! Due to a flat rural site none of mine is below grade. I used wood framing on all four sides with #1 railroad ties at 8 feet O.C. for posts set in concrete in augured holes, treated 2x6 horizontals (spacing varies with pool depth) between the ties with galvanized connectors, AWWF ply for the walls, and a flat 2x6 at the top for added depth and stiffness. It will be capped off with a wood deck that laps the edge about an inch and transitions to a deck on two sides. The slide is already up and the solar panels will go on the south side on sloped supports tied to the pool posts. I expect it will last as long as I do. Thanks for the inspiration and great pictures.
    Sep 2013
    Dallas, TX
    25
    I am so glad to hear of some wood framed pools. I would love to see some pics and details of how your pool was built. We are wanting to build a 16x32 to 20x40 in the next few weeks and could really use some insight--and eyesight about what you have done. There is so little else available. I am also curious where you bought your plywood--can't seem to find anything but typical warped pressure treated here in Dallas area. Also how did you do 8 ft. spacing between railroad ties--wasn't that too far between 2x6--hope not as it would be cheaper. Last question is you stated the spacing between 2x6 varied with pool depth. I don't understand. It sounds like your site was level, and I assume you put the horizontal 2x6's horizontal, so didn't catch what you meant by depth. I would be so grateful for any insight, and pics of your pool. Thanks
    Apr 2013
    Central Massachusetts
    174
    Quote Originally Posted by milescity View Post
    Milescity, do you have a build thread? I find these wood framed pool builds interesting!
    26,000 gal 18x36' IG Vinyl Pool - Hayward S244T Sand filter - Hayward Tri-star 2-speed 1.5HP pump - Goldline Aqua Plus SWCG and Controller with Tcell-15 - Aquacomfort 125K BTU Heatpump - Hayward Color Comfort 4.0 LED - Zodiac MX8 suction cleaner - TF100 test kit
    My Build thread
