Results 1 to 12 of 12
Thread: Aquarite Goldline Controls -What do the numbers on LCD mean?
    Our pool was built about 6 weeks ago. It is 18 X 32 ft (~20000gal) vinyl linered salt water filter (SWG) automatic chlorine generator with Aquarite (Goldline) control box.
    What do each of these numbers mean when we press the diagnostic button. With each push of the button, the numbers cycle
    2.50
    31
    30.9
    0.00
    41P
    -0.00
    AL- 0
    !- 1.50
    t- 15
    Output knob is set at 40%.
    The Aquarite manual is rudimentary and does not help.
    My 8 year old is complaining of eyes burning.
    thanks
    IG (built 7/09) Vinyl Liner 18 X 32ft Rectangle, ~20K Gallons, Aquarite SWG Chlorinator, Hayward Sand Filter (Pro Series -S244T), Hayward SuperPump (SP2607 X 10)
    New2Me's Avatar
    Jun 2008
    SW Indiana
    322
    Re: Aquarite Goldline Controls -What do the numbers on LCD mean?
    Google is your friend(I find it handy, too!), I went here -
    http://www.goldlinecontrols.com/Support/Manuals.aspx
    and chose the Installation and Operation Manual for Aqua Rite (standard) and Aqua Rite XL
    on page 17 of the pdf file(page 14 in the paper manual)
    Diagnostic Displays
    Sequential pushes of the small "diagnostic" button next to the LCD display will
    cause the Aqua Rite to display the following information:
    1. Pool temperature (xx degrees Fahrenheit or Celsius)
    2. Cell voltage (typically 22.0 to 25.0 volts when chlorine is being generated, otherwise
    30-35V)
    3. Cell current (typically 4.50 to 7.80 amps when chlorine is being generated, otherwise
    0 amps)
    4. Desired Output % ("0P" -- "100P" depending on knob position or input from remote
    pool automation controller)
    5. Instant salinity ( -xxxx ppm or -x.xx grams/Liter)
    6. Product name sent to the pool automation control display ("AL-0" which signifies
    "Aqua Rite")
    7. Software revision level (r1.xx)
    On the 8th push of the button the display will revert back to the default salt display.
    Also, if the button is not pushed for 30 seconds, the display will revert back to the
    standard salt display.
    1. So it looks like your SWCG calls itself AL-0, has software version 1.50.
    2. Your salinity is 2.5 grams/Liter (2500 ppm is kinda low, you might need to add salt)
    3. Pool temperature is 31(probably celsius?)
    4. Cell voltage is 30.9 Volts and current is 0 amps(it was not on when you were reading it,)
    5. Your output knob is set at 41%.
    You either wrote some of these numbers down out of order, or I found the wrong manual! The more detail (Model numbers, names etc..) about your equipment that you can provide, the better answers you'll get. You can put the info in your signature line. It would be helpful for you to read the Pool School part of the forum to gain a better understanding of the terminology people use here, and how easy it is to enjoy your pool with minimal trouble. Ph is usually what causes eye irritation, with a SWCG, it will rise if you don't add acid as needed. The only way to know when it is needed is to have a good test kit, and employ it daily. Once you feel comfortable enough with the way your pool behaves, you'll love the SWCG!
    Welcome to TFP! and Best Wishes
    22 x 40 IG vinyl lined, 23,570 gal.
    1 hp. Pac-Fab Challenger pump 300# sand filter
    Intex 8110 SWG, Hayward CL220 offline feeder
    Hayward 250K Btu gas heater
    Aquabots
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    You have to wait ~ 1 minute to get the actual numbers
    Please try again :P and we'll help you with what's going on
    Luv& Luk
    -Ted
    May 2009
    Enterprise, AL
    54
    The last number t-15 stands for the turbocell 15, the one for up to 40k gallons. This is a relatively new, 8th diagnostic number, so the 9th push of the button takes you back to the average salinity.
    The reason your instant salinity is zero is because it wasn't generating at the time.
    20K gal IG vinyl 18'x36' rectangle, 2' radius corners
    Hayward Goldline Aqua Rite 40K SWG, Pentair Intelliflow VS 3050,
    Sta-Rite Cristal-Flo 24" Sand filter, Model T-240BP-1, Polaris 280 Auto Cleaner
    Sunstar solar panels (438 sq ft ), Pentair Sun Touch Controller automating solar panels, SWG, and Polaris
    TF-100 test kit
    mickey4paws's Avatar
    Apr 2009
    S.E. MI
    571
    Sometimes you can hear the SWG make a click sound and that is when it is generating and you can read the numbers on the panel. You can also change it to read Fahrenheit instead of Celcius if you prefer, as follows:
    The factory default display is in English units (ppm). If Metric units (grams per liter) are
    preferred, push the small button next the display once. The display will now show the
    pool temperature. With the temperature displayed, move the main switch from AUTO to
    SUPER CHLORINATE and back to AUTO. The temperature display will instantly switch
    to Celsius and the salt display will switch to grams/liter. Repeat this process to switch
    back to English units. (ppm and Fahrenheit)
    IG 12' x 39' - 20k Gallons - Vinyl Lined - StaRite Cristal-Flo II 26" Sand Filter - Hayward SuperPump 1 hp - Dolphin Dynamic autocleaner - Lochinvar Energyrite gas heater - Aqua Rite SWCG T-15 - TF100 Test Kit - Skimlite Duallly 9016 pole (great pole)
    Bob_Funk's Avatar
    May 2009
    Seattle-It really rains all the time
    113
    Quote Originally Posted by Cyclops
    Can you post a current set of test results.
    I consider myself very lucky I found this site before the pool store found me-pool owner since Nov 2008- Stunningly clear 17,000 gal fiberglass pool, thanks to this site, installed in 1982-24" 3.1sq. ft sta-rite sand filter, 1 hp - 2 speed wisperflo pump-WFDS-4
    Thank you for all the responses. We are learning a lot thanks to this forum.
    The readings this afternoon (after changing the unit of measurement) were..
    2500
    86
    24.6
    5.51
    41P
    -2600
    AL-0
    r 1.50
    t-15
    check salt and check cell lights have been flashing for a week.
    for the person who asked for a current test results ....you mean a water analysis.... we haven't tested the water at home. A water analysis at a pool store last week reported high chlorine. They advised not to do anything and to retest in a week. They also said since the chlorine level is too high it makes all the other levels like ph etc unreliable!?
    Bob_Funk's Avatar
    May 2009
    113
    Hi Cyclops,
    I was asking for test results, they tell the condition of your water, & may shed a clue as to why your child's eyes are burning
    pH -
    TA - Total Alkalinity
    FC - Free Chlorine
    TC - Total Chlorine
    CH - Calcium Hardness
    CYA - Cyanuric Acid (stabilizer)
    not the readings from your swg.
    Apr 2009
    S.E. MI
    571
    I would recommend bringing up your salt level. These panels are known for showing a lower level than the actual salt level because they test using a formula of TDS (total dissolved solids). Go to the Pool Calculator on this site, and enter the number of gallons of your pool. Then put in 2600 for your current level and 2900 for the level you want to bring it too. It's better to add too little salt at first, than too much because if you add too much, you will have to drain some water and refill. I would also recommend getting some salt test strips, such as the Aquachek ones. They are more accurate than your panel.
    Re: Aquarite -LCD numbers & Testing Kits Vs Strips
    Being absolute newbies, I have a few questions on testing kits/strips.
    I assume we can do all the testing at home if we have the kits. So far, we went to the nearest pool store for testing.I see from my research here, there are mainly two type of kits, Tft and Taylor. Also, I hear about strips.
    1). What is the difference between the kits and strips? Is it that Kits can test all the required parameters whereas strips are limited to one or few but easier to test. How labor intensive is testing with kits? Any accuracy issues with each?
    Which one should we buy?
    2). Shelf life of kits. As the swimming season will shortly end here with the onset of fall (shedding leaves, falling temps) in about a month or so, if I but a kit next week, will it be good for testing for next season?
    thanks
    Apr 2009
    S.E. MI
    571
    I believe the test kits such as the TF100 and the K-2006 are more accurate than test strips and pool store testing (with the exception of testing for salt, the strips are supposed to be pretty accurate). Here is a comparison between the TF100 and the K-2006:
    pool-school/pool_test_kit_comparison
    As far as how long they last, hopefully someone who knows will post. I would think as long as it's stored properly, it should last through next season as well.
    When I first got my TF100, I was pretty intimidated, having never tested before. I was surprised how easy it was. I actually like testing, it's like having your own chemistry set to play with
