Thread: Calcium hardness test. What does it measure?
    Hi All,
    Just curious what the calcium hardness test actually measures and what units it measures in, maybe ppm? I couldn't figure it out based on the instructions.
    Joe
    PS no jokes that it measures "calcium hardness"
    15,500 gal, inground gunite pool with 7 ft spa, 2 speed pump 2hp/.33hp, 3/4 hp booster pump, Intermatic P1353 timer, AutoPilot SC-48, Sand filter with ZeoBest, Heater, that I never use . . .
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Calcium hardness test. What does it measure?
    I believe it is ppm of Calcium Carbonate. See here.
    Mark
