Thread: What gonna happen if pool have boron more than 80 ppm?
    What gonna happen if pool have boron more than 80 ppm? How to fix it?
    Jul 2009
    London and France
    574
    Re: What gonna happen if pool have boron more than 80 ppm?
    Nothing if you don't drink it
    Drain off and top up with fresh or bomb dive a lot.
    You need to replace water to lower the borate level. High borate levels can potentially be toxic. This doesn't happen right away the moment you go above 80, so it depends on just how high your borate level is. On the other hand, it isn't something you really want to risk, so best to lower the borate level to 80 or lower fairly soon.
    Mar 2007
    San Rafael, CA USA
    12,082
    There's more on boron safety/toxicity in this thread. The EPA considers borate levels above 360 ppm to be above the margin of exposure (based on children swallowing a small 2 ml amount per day) and do not allow products that dose above that rate. However, as Jason said it is a toxic chemcial and it's not something you would want to regularly ingest every day. Mostly we tell people that they should train their dogs to not drink from a pool that has borates in it. 50 ppm is the recommended level for most pools and 80 ppm for Baqua/biguanide/PHMB pools.
    Thank you teapot, JasonLion and chem geek.
