Results 1 to 11 of 11
Thread: Greetings all, Newbie to the forum
    morrodds's Avatar
    Aug 2009
    Leona Valley, CA
    10
    Hi - I'm Martin and have just finished building a vinyl lined, wood walled pool on a slope. I've perused this forum for a few weeks and am impressed with the camaraderie and info disseminated. Pool School is very nice - kudos to those who compiled all the data and directions.
    Since I'm starting up the pool, I've ordered the TF100 test kit. The local pool store gave me the following #s this AM:
    pH 7.4
    TA 60
    TC 0
    CH 80
    CYA 0
    I've added a gal. of 6% bleach every other evening since Sunday. With no CYA, I guess it's gone in no time. I'm ~50 miles north of Los Angeles and we get LOTS of sun.
    From the Pool Calculator I estimate I'll need 2.5#s baking soda, 4 #s CYA and a little more than 2 qts of 12.5% liquid chlorine. Do I need to shock the pool?
    Thanx, Martin
    17k gal., sorta IG vinyl, 1.5 hp pump, 21" sand filter, Shark robotic cleaner.
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Re: Greetings all, Newbie to the forum
    You should keep adding your bleach but I think I would do it nightly since there is no CYA in the water right now. You need to get some CYA in there to help with slowing down your chlorine loss during the day time with the hot sun!
    Welcome to the forum BTW and some pics of your pool build would be nice if you have any to share. We always love to see pics !
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    22,549
    From your numbers it doesn't really look like it. It's hard to tell though without a full set of numbers. Especially FC and CC. You also need to do an overnite chlorine drop test. You can do that once you get the test kit.
    Right now I'd go ahead and add the CYA at a return or in the skimmer and add the recommended chlorine. Then you can add the baking soda.
    I'd add about 48oz of chlorine a day until you get the kit just to make sure you're keeping the FC up. If you get it a little high, you can always let it drift down once you get a good test on it.
    Butterfly's Avatar
    South Carolina
    10,045
    Hi Martin,
    Congrats for getting off to a good start with your new pool
    I agree that you should get your CYA in ASAP. Also, since you have "lots of sun", you might want to think about CYA of 40 instead of 30.
    Ditto on the "we love pix"!
    You're done SLAMing when:
    morrodds's Avatar
    Aug 2009
    Leona Valley, CA
    10
    Thanx for the encouragement. Got the CYA and baking soda in tonight.
    After reading all the concern about excessive CYA on vinyl, I thought I'd wait a week before bumping it higher. Since I use a sand filter would the backwash/waste water compensate for the CYA if I used an in-line Trichlor tablet feeder? I've read about the evils of tablets but would like the convenience.
    I took some pix of the construction project - where should I post them - here or under construction?
    Here is the present progress - ladders and enclosure for the cover are next.
    Later, Martin
    Arizona
    924
    Boy, you sure have a pretty view from your beautiful new pool.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    Bob_Funk's Avatar
    May 2009
    Seattle-It really rains all the time
    113
    I second that, you have a gorgeous view
    Beautiful pool
    I consider myself very lucky I found this site before the pool store found me-pool owner since Nov 2008- Stunningly clear 17,000 gal fiberglass pool, thanks to this site, installed in 1982-24" 3.1sq. ft sta-rite sand filter, 1 hp - 2 speed wisperflo pump-WFDS-4
    Butterfly's Avatar
    South Carolina
    10,045
    Stunning view! Very nice pool, too
    It would be great if you started a thread in the construction forum for the build project.
    morrodds's Avatar
    Aug 2009
    Leona Valley, CA
    10
    Thanx again for the compliments. It's hard to believe this is only an hour from LA.
    That's the Leona Valley Vineyards below ( nice of them to have planted it after I bought the place ). We have cherry, pear and apple orchards along with horse ranches. Fortunately the horses are far enough away so we don't have the flies.
    Here's a shot from 2 years ago:
    I'll make a thread in the build section.
    Martin
    Jan 2009
    Cupertino, CA
    1,966
    Quote Originally Posted by morrodds
    Backwashing wouldn't really help enough. Suppose you need to add 10ppm FC per week (around 1.5ppm per day, not unreasonable in summertime). If that's all from the tabs, you will also get 6ppm CYA. So, in a month you've raised CYA by around 25. Let's say you started at CYA 50 (again not unreasonable for a sunny climate) then after a month you're at 75, and need to dump 1/3 of your water to get back to 50. Now each pool is different but whether it takes 1 month or 2, eventually your CYA will be too high. You're not going to backwash that much, not in a clean pool.
    The tabs are great for vacations, but for everyday I'd use at most one at a time just as a supplementary source of FC.
    --paulr
    BBB "Intermediate Swimmer"
    mickey4paws's Avatar
    Apr 2009
    S.E. MI
    570
    I haven't read anything about that. What do you mean?
    Your pool is gorgeous, Martin, as well as the area you live. Enjoy your new pool!
    IG 12' x 39' - 20k Gallons - Vinyl Lined - StaRite Cristal-Flo II 26" Sand Filter - Hayward SuperPump 1 hp - Dolphin Dynamic autocleaner - Lochinvar Energyrite gas heater - Aqua Rite SWCG T-15 - TF100 Test Kit - Skimlite Duallly 9016 pole (great pole)
