Thread: Run Times: Pump SWG?
    new pool owner here and i have a question: i have a Goldline SWG, 12,200 gallon ingound pool, pebble-tec, 1.5 hp Jandy pump. I have cut teh pump time down to 5 hours a day and the water is nic eand clear. Question: what setting should my SWG dial be set to? when i cut the pump run time form 6.5 to 5 grs, i turned the dial from 40 to 50. do yo uthink that will be good?
    hayward cartridge filter c1200
    ao smith 1 hp motor
    22700 inground fiberglass
    no cal
    Mar 2009
    Glendora, California
    Re: Run Times: Pump SWG?
    You need to measure how much CYA is in your pool. The amount of CYA will determine what chlorine level you need to maintain. Give Pool School a read then read it again and it will start to make sense.
    18k Inground Plaster pool / TriStar Variable Speed Pump and Controller
    48sq ft Hayward DE filter/ Swim pure Plus 40k cell / Kreepy Krauly
    Solaxx Ph-Tek
    Forget about the dial. What are your CYA, FC and CC readings? These readings are the only thing that is going to tell you if you're producing enough chlorine.
    Edit: Another reason to ignore the numbers on the dial: when the amount of sun hitting your pool changes, you're going to have to adjust the amount of chlorine output. It'll change from month to month.
    ~18000 gal in-ground pool
    Zodiac C170S SWG
    Hayward top mount sand filter
    Hayward Pool Vac Ultra
