Thread: New Pool Owner - pool equipment explained?
    Jul 2009
    Massachusetts
    188
    Hi, I'm closing on our new house on Friday and already have my TF100 test kit ready to go. Can't wait to run my first tests. I was at the house last week and took some pictures of the equipment to hopefully get some feedback on the quality of the models. The pool was installed in 2002. It is a 17000 gal (approx) gunite kidney shaped pool with a waterfall. The equipment is listed below:
    Aerotemp heat pump, Model AT12000-A, BTU/KW output 92000/26.96, 60Hz - is this an efficient model for the size of my pool?
    PB4 Booster Pump - Copper conductors - this is strictly for the pool cleaner, right?
    Hayward Vari-Flo model SP715XR50, Rated pressure 50PSI, Rated Flow 125GPM
    AOS UST1202 Motor, googling shows it's 2HP
    Meyco pool cover
    Pentair Model 320 Auto Chlorine Feeder
    Hydro-King T104P201 Timer
    Polaris Cleaner, I think it's a 380 - while we were there, it was running in the pool and the tube that extends from it that appears to blow water/air, occasionally sprayed water out of the pool - is that normal?
    I'd like to pick up a Solar Pool Cover to help with the heating - is there a recommended brand?
    Thanks in advance.. I'll probably be posting again on Friday with my test kit results to make sure I'm doing the right thing
    Love this place!
    25,000 gallon gunite pool with waterfall (built 2000 - owner as of 2009), Aerotemp / Aquacal heat pump AT12000-A, Hayward DE4800 Filter, AOS UST1202 Motor, Hydro-King T104P201 Timer, Meyco pool cover, Pentair Model 320 Auto Chlorine Feeder. Located in Massachusetts.
    May 2008
    Virginia Beach, VA
    84
    Re: New Pool Owner - pool equipment explained?
    Quote Originally Posted by patplh
    No such thing as an "efficient" pool heater! You'll just need to experiment with runtimes to see how fast/slow it heats the pool, and your tolerance for electric bills! Getting a solar cover will be a big help to minimize heat loss overnight.
    More than likely this is just for the Polaris cleaner, but you'll want to spend some quality time with your new pool tracing out which lines go to which returns, etc..
    There is a backup valve on the hose that kicks on every few minutes to drag the cleaner away, helping to free it from any obstructions. There is also a "tail" that sprays water, to blow small particulars off the floor of the pool. If the cleaner climbs a wall, that tail sometimes comes out of the water for a second and it will spray up. Pretty funny if someone gets sprayed walking by the pool!
    From my reading, there doesn't seem to be a consensus on a brand, much less the other factors... color and width. These covers usually only last 3 - 5 seasons, so some folks like the thinner covers because they are lighter and easier to handle. Search the forum for solar covers and I'm sure you'll find lots of articles.
    Congratulations on your new house and pool!
    28K IG Vinyl lined pool - 1 skimmer, 2 returns
    Hayward DE 60sqft filter; Polaris 280 vacuum with booster pump
    Mar 2007
    Coastalish 'down easter'
    4,160
    Pat, welcome to TFP!!
    IMHO, you are doing a GREAT job of getting to a 'Trouble Free Pool'!!!
    You left out your filter but from the multiport # I know it's DE and has 2" piping to it :P If you haven't, check out my advice for DE filters here.
    It really sounds like you've got a good grip on your pool and what you need to do!
    I'd like to hank you for being so diligent in your care and for getting the best test kit and supporting this site
    If I can help further, please feel free to call upon me!
    Luv& Luk
    -Ted
