Results 1 to 7 of 7
Thread: Are R-0871 and "FAS-DPD Titrating Reagent" the same?
    Jul 2008
    South Eastern PA
    40
    I would like to know if the R-0871 that comes in the TF test kit and the "FAS-DPD Titrating Reagent" that can be purchased from leslie's (link: http://www.lesliespool.com/browse/Home/ ... 30/I/81348) is the same?
    When I called Leslie's they seemed confused about what I was asking and then indicated they didn't carry it, but I am thinking that this is what I am looking for.
    -Brock
    8200 Gal Vinyl 18' AG Vogue Pool
    150lb Hayward Sand filter with 1-1/2 HP Maxim Pump
    Intex SWG
    Some of the most helpful links for pool owners: Pool School | Pool Calculator | The best test kit | Chlorine/CYA chart
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Are R-0871 and "FAS-DPD Titrating Reagent" the same?
    why not just ask them what the code is that's missing on their picture R-???
    The TF100 uses Taylor reagents so the code should be the same. Just curious, why not order from Dave at tftestkits.net...about the same price plus you get 1oz vs .75 oz
    Jul 2008
    South Eastern PA
    40
    Normally I would order from TF test kits, have in the past.. but didn't realize I was running low when I ran out... and I would like to test before a picnic this weekend. I am afraid if I order from tf test kits that it wont get here in time, and I have a leslies about two blocks from work.
    Trust me, if I had the time to wait for it to arrive, I would much rather give Dave my money than leslies. In fact I will be placing an order with him shortly for other reagents soon, but just need the 871 quicker than that.
    Intex SWG
    If you actually go to the store and see the reagent before you buy it, it will say R-0871 on it. Not very many of the Leslie's stores actually stock this reagent and quite a few of the sales people will insist that some other reagent is the correct one, when it isn't. Since they are Taylor reagents, look for the Taylor R-0871 label.
    skydiva44's Avatar
    Houston, Texas
    200
    My Leslies claimed they didn't even know what R-0871 was...
    ABG Easy Set 18 x 48
    5455 gallons
    SWG
    Intex Pump 4000 GPM - Size B cartridge
    Jun 2007
    New Jersey
    653
    One unhappy day I ran out of R-0871 and I grabbed my retired DPD reagent instead of my reserve R-0871 when I didn't have my glasses on. (Both have those opaque reddish Taylor drop bottles--I didn't know the other stuff was still around.) It took three days to figure out my mistake. If used with FAS-DPD it has no effect. A pink sample will stay pink no matter how many drops you throw at it. A clear (FC=0) sample will stay clear. This happens when you stop adding chlorine while you try to figure out why your FC is infinite. Your FC drops to zero and then sample is clear. Your pool will also have algae. Just don't go there, please.
    Edit: However, the stuff in the link is R-0871 and says so as Jason says. My story is about what will happen if the store gives you the other stuff(Regular DPD)
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    Bob_Funk's Avatar
    May 2009
    Seattle-It really rains all the time
    113
    Quote Originally Posted by skydiva44
    You can't possibly believe they were lying can you?????????
    That is the one statement I actually believe from the pool store.
    I consider myself very lucky I found this site before the pool store found me-pool owner since Nov 2008- Stunningly clear 17,000 gal fiberglass pool, thanks to this site, installed in 1982-24" 3.1sq. ft sta-rite sand filter, 1 hp - 2 speed wisperflo pump-WFDS-4
