View Poll Results: Do you still have problems with your Liquidator?
Voters
18. You may not vote on this poll
  • I don't have any problem now
    13 72.22%
  • I have a problem but I can live with it
    2 11.11%
  • I have a problem that cripples my LQ
    1 5.56%
  • Because of the problems I dumped my LQ
    2 11.11%
Results 1 to 13 of 13
Thread: Do you still have problems with your Liquidator?
    Water_man's Avatar
    Jun 2008
    Brookline, MA
    390
    Last year we had numerous posts regarding Liquidator problems related to installation, flow, and WS issues. These problems and issues were dealt with by many contributors and many of them seem to have been solved. This year the activity is very low.
    There could be three reasons for this:
    1. The most favorable one: Most or all or the problems can be solved because of the huge body of knowledge collected here since last year.
    2. People gave up and live with their problem.
    3. People just got sick and tired of their LQ and dumped it.
    I wonder, does anybody still have any unsolved problem with his/her LQ which impairs its performance? If you have WS but it doesn't affect the flow or performance then your problem is aesthetic and it doesn't count.
    This is my ticket for Heaven (when all's working..) :
    22k Gal gunite IGP, 38 SF Anthony DE filter, 1 HP Hayward Super Pump
    380k BTU Raypak Natural Gas Heater (Model RP405A) and solar cover
    8 gal Liquidator w/ 12% bleach, Dolphin Diagnostic Advantage robotic cleaner. 3800 ppm salt, 50 ppm borates.
    22,539
    Re: Do you still have problems with your Liquidator?
    Thanks for posting this. I just bought a Liquidator from another member and I feel confident that I can overcome any problems associated with it because of the excellent info I've read about it here. I'll be keeping track of this thread/poll.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    The only way mine could be better is if it went to the store an brought the bleach home itself.
    Feb 2008
    Milford, CT
    333
    The tubing on mine has "whitened over", but it doesnt seem to be causing any flow issues currently.
    I have all the parts ready to go for the upgrade to 3/8" tubing, but like they say "if it aint broke dont fix it". I might wait until next season to upgrade it.
    22K IG vinyl, .5HP Northstar pump, S244T filter, AutoPilot Digital w/SC-48 cell
    Water_man's Avatar
    Jun 2008
    Brookline, MA
    390
    Quote Originally Posted by chrisexv6
    Do you see the WS in the flow indicator too? If the WS bothers you, you may add 50 ppm borates and enjoy all the benefits of borates, including most likely WS prevention.
    If your flow is adequate there's no reason to change. I switched to 12% bleach so I run to the store half the time and I can use a low flow.
    jwfrank's Avatar
    Oct 2008
    Todi, Umbria, Italy
    55
    I love my LQ, installed in June. I started with 50ppm borates this year, use 12% bleach, and have no WS problem. Based on posts, I try to minimize stirring up the "stuff" that seems to collect at bottom of LQ, when I add new bleach. I do this by: suctioning bleach from a 25kg container into the black funnel and using a piece of the plastic tubing to get the flow as low as possible into the funnel. When I clean the LQ after the summer, I will undo the two pieces of the funnel and thread this tubing beyond the clip that holds the two pieces together
    I get a max flow rate of only about 3, but that seems enough to keep my pool at 5-7 ppm FC which is enough for my pool usage and CYA level. (I run the pump about 12 hours on a timer)
    PS:I too was surprised by how few posts there have been this year after flurry of activity last year
    krcossin's Avatar
    Detroit Burbs
    113
    I would say the Liquidator has been the best thing I have added to the pool. Very easy to check the level, fill, and adjust the flow.
    Toss out the **** tubing it comes with and upgrade them.
    2007 - 24' AG Doughboy Desert Spring dished 1.5', with DB Power Pak II-1hp pump, DB Sequel I Plus DE, Hayward H-Series Heater 100k + 8gal LQ.
    JoseJones
    Guest
    I never actually had any problems other than the install was a bit dicey at moments.
    I haven't dug around the posts, but I use the 12% Cl and it seemed that anyone using lesser % were getting the WS, which was the big complaint.
    Also, since installing the LQ I've had to shock the pool very little. The pool just stays happy all the time!
    Best pool investment so far!
    Aug 2007
    Austin, TX
    341
    I love my LQ and pH Adjuster. After two summers and going into it's third winter, no issues to report. During the heat of our summer (68 days of 100 plus days) my LQ couldn't keep up, I had to add an extra jug of chlorine to the pool manually. Not a big deal and not unexpected.
    20k Gunite/Prism Blue-Pebblesheen, Pentair Tagelus TA-100D Sand Filter, Heliocol Solar Water Heater, 2 bubblers and 2 waterfalls installed 2007, 3hp IntelliFlo VS Pump 011018 installed 2013, Aquabot Turbo T4 RC and Stenner 45MHP10 w/The Liquidator container installed 2012.
    Antigua Spa by Artesian Spas: 325 gl, 52 jets, 6 hp 2 sp & 6 hp 1 sp, Circulation System 24 Hour Whisper Pure, Ozonator, LED digital lighting, The Artesian Pillowfall installed 2007.
    Retired: 2hp Pentair Whisperflow, Legend Platinum w/booster pump, PH Adjuster
    Jun 2007
    SF Bay Area
    441
    Sabot,
    How often did you have to add the extra chlorine? Daily? Weekly?
    24,000 gallon inground freeform pool/spa circa 1983 (113 ft perimeter, 625 sq ft) with 350 gallon attached spill-over spa
    2007 2 HP, three-phase Hayward TriStar pump which is powered by an Ikeric VS-200 variable speed drive system
    1983 Laars XE Pool/Spa Heater Type ES 400,000 BTU, 1998 Hayward Super Star-Clear C-4000 cartridge filter (400 sq ft, 4 separate cartridges)
    1998 Polaris 380 pressure-side cleaner w/ 3/4 HP booster pump
    One skimmer :( and one PoolSkim :), One Supervision Galaxy LED pool lamp, Second story solar panels
    Hayward/GoldLine AquaLogic PS4 (replaced 1983 vintage dual circuit Intermatic timer)
    Aug 2007
    Austin, TX
    341
    1 jug a week.
    Water_man's Avatar
    Jun 2008
    Brookline, MA
    390
    Quote Originally Posted by Sabot
    Do you get max flow out of your LQ? If you've used 6% bleach, converting to 12% can solve this minor problem.
    Aug 2007
    Austin, TX
    341
    I have not looked for a 12% dealer. I buy mine from Sams at $8.12 per case of three jugs of 6%. I understand what the LQ can do and can't, no big deal to help it out for two months. It works perfect for the other 10 months. I run it maxed out during the summer then dial it back during the off season.
