Thread: muriatic vs. sulfuric
    Aug 2009
    Bradenton, Florida
    11
    Pool store guy said if your pH and Alkalinity are both high you would use muriatic to bring them down. If only pH is high you use sulfuric, as it has little impact on Alkalinity. Any thoughts?
    8 K pool, cc 100 filter, Auto-Pilot SWG, 1 HP Whisper-Flo pump, in-ground gunite pool 9 yrs. old,solar heat and Pentair 250K heater.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: muriatic vs. sulfuric
    He's wrong. Lowering the pH of the water changes the form of some of the carbonate in the water to carbon dioxide, which reduces the measured alkalinity and makes it possible to remove it from the water by aeration. It doesn't have any permanent effect on the alkalinity unless you aerate the water to remove the CO2The alkalinity doesn't care how the pH got lower.
    Muriatic acid contains hydrogen and chlorine, both of which are normal in a pool. H2SO4 leaves sulfur behind.
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by JohnT
    Just for clarity, the "chlorine" in Muriatic Acid is chloride - that is part of salt. The dry acid leaves sulfates behind.
