Thread: Stabalizer Test Kit
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Stabalizer Test Kit
    I was just curious on the opinions on which stabilizer test kit is most accurate.
    Right now the one I use looks like this one here on the left
    http://www.poolplaza.com/P-SALT-COMBO-TEST-KIT.html
    It basically involves mixing water and the regent, waiting 2 minutes and then adjusting the slide until the black dot just disappears from sight when looking from above, then the measurement is read by looking at the markings on the vial from the side.
    I've also used test strips and the color q device
    the test strips work well for telling you when the stabilizer is toooooo high. The color q device seems to be always reading very low.
    Let me know what you guys think!
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    30,431
    Re: Stabalizer Test Kit
    No question. The one you are using (and the Taylor test method) are the most reliable by far. The Taylor view tube doesn't have the nifty slide but it's noticeably less money. The disappearing dot is the method they both use.
    Test strips are usually pretty innaccurate on many things but appear to be horrible on CYA.....and horrible is not an exageration.
    The color Q is just as bad. It fails miserably at consistent, accurate CYA testing.
