Thread: Stabilize qusetion...liquid or solid
    rdkll's Avatar
    Jul 2007
    Huntsville, AL
    41
    Hey, I have lost the handle on my pool, it is green and its because of low cya and not enough chlorine......
    Any thoughts one way or the other.......
    Thanks
    1) The size of your pool in gallons = 33,500 16x32x40 L
    2) The type filter you have = 300lb Sand
    3) IG
    4) If it's IG, vinyl liner
    5) pump is 1.5hp
    Re: Stabilize qusetion...liquid or solid
    Solid, it is much less expensive and works just as well.
    rdkll's Avatar
    Jul 2007
    Huntsville, AL
    41
    I used the pool calc and for 0 to 40 to add 160 oz by weight or 167 oz by volume. I am using 30000 as the number of gallons. Not sure of the difference.
    3) IG
    5) pump is 1.5hp
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    By volume would mean if you were using a measuring cup to dose, by weight is using a scale or container size. CYA is found in 1, 2, 3 and 4 lb containers, larger containers over the internet.
    chris4150's Avatar
    Apr 2009
    Cypress, TX (suburb of Houston)
    180
    You can easily look up conversions for cups to pounds etc. For example, two cups is equl to 1lb dry weight. So if you have to purchase more than your required 10 lbs and dont want to guess, bust out a measuring cup and start pouring your dry stabilizer. Hope this helps.
    13,500 gallon free form Pebble Tec pool- 2 skimmers
    Pentair Intelli-Flow filter pump, Pentair Intelli-Super Flo booster pump, waterfall pump, Del Ozone Eclipse 1 generator, Pentair Clean & Clear Plus Cartridge filtration, Nature 2 XG Clear Vision, In-line Chlorinator, Polaris 280, Raypack heater, and Color Logic LED lights.
    Proud user of BBB, pool school, pool calculator, TF-100, and the advice of the friendly people here!
    chris4150's Avatar
    Apr 2009
    180
    Quote Originally Posted by chris4150
    this will help.
    http://www.ez-calculators.com/measureme ... ulator.htm
