Thread: CYA question
    Jul 2009
    Virginia Beach, VA
    66
    CYA question
    Hey all, I'm a recent converter from Baqua so although I know those chems like the back of my hand I am in the process of really learning all the ins and outs of chems for chlorine pools.
    Got a question about CYA. I did a test and i have my CYA at around 40 which was my goal, I understand about getting the CYA down you have to replace water, so I have a question about standard evaporation. Does CYA get lower (quickly) from normal evaporation and water replacement. I expect as usual to replace 1 - 2 inches of water a week. What is everyones normal testing cycle for CYA (once a month, once every 2 months, etc). Thanks
    Dennis
    24ft AG pool, about 13,600 gal I think
    200lb Sand Filter
    2.5 hp 2 speed pump
    recent Baquacil CONVERT and loving it.......
    30,403
    Re: CYA question
    Evporation and refill does not reduce the CYA.
    I check mine about 4 times each season.
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Re: CYA question
    I usually check mine like Duraleigh unless I suspect a problem with it.
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
