Results 1 to 8 of 8
Thread: High pH and TA
    High pH and TA
    I can't seem to keep my pH at a manageable level without using tons of MA. I get it down to 7.2-7.6 and it jumps back up. I am currently at 8.2. Ideas?
    2003 Marquis Euphoria - 400gal
    Re: High pH
    BTW... my TA is 160.. perhaps that is the culprit?
    Re: High pH
    Talking to myself here... :P
    My TA was 200 in April.. I have added 6gal on MA since then.. shoudn't my TA now be closer to 80?
    6gal = 24 qts * 5 TA I shoud be losing per qt = 120approx 200-120 = 80
    Jan 2009
    Cupertino, CA
    1,966
    Re: High pH and TA
    Have you added any water since April? My TA was going up over the summer, which befuddled me until the doh! moment of remembering my fill water has TA 150.
    --paulr
    BBB "Intermediate Swimmer"
    Re: High pH and TA
    Yea.. I add 3-5" every 7-10 days. I have not tested the TA on my fill water.
    Re: High pH and TA
    Yes, your PH is going up because of your high TA.
    You should test the TA (and CH) level of your fill water. That is probably where your high TA comes from in the first place.'
    Lowering TA down to around 80 would dramatically reduce the rate of PH increase.
    Re: High pH and TA
    Thanks... how much MA can I safely add at one time?
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: High pH and TA
    You only add enough acid at one time to lower the PH down to 7.2. You don't want to go lower than 7.0, regardless of the TA level.
