Results 1 to 7 of 7
Thread: Please check my plumbing diagram.
    Vero Beach, FL
    462
    Here is what I think is a good schematic for my pool. The PB will be plumbing the equipment next week.
    Do you see any problems or changes that would improve it?
    [attachment=0:4g9zahxk]Pool Plumb.gif[/attachment:4g9zahxk]
    25' x 13' Roman, 12000 gal IGP, Plaster, with 500 gal Spa
    SWG, 1 HP Max Flo Pump, C-900 cartridge filter
    Solar heat
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Please check my plumbing diagram.
    The only change I would make would be to separate the main drains from the spa and pool. If you use a controller, it would have to set 3 vales to change from pool to spa (A,C & F). If you only have the spa on the left side of valve C, then you would only need to change two valves (C & F). The pool main drain can then be set up as you did for the skimmer. All pool stuff should be on the right side of C and spa on the left side of C much like valve F setup.
    Mark
    22,553
    It looks workable but if it were me, I'd change/move a couple of valves to make it more versatile.
    1) I'd change valve "A" to a block valve and move it to the spa drain.
    2) I'd change valve "C" to a block valve and move it to the pool drain.
    3) I'd change valve "F" to a block valve and move it to the spa jets.
    4) I'd add a block valve "G" to the pool return.
    That way you could pull water from one or any combination of suctions and return water to either or both returns.
    You'll just have to be sure not to close all the valves on either the suction or return at the same time. You can already do that on the suction piping like you show it now.
    mas985's Avatar
    Pleasanton, CA
    11,742
    That would work ok without automation but with automation, it is easier and requires less relays to have only one valve each on both the suction and return lines to switch between spa and pool.
    [EDIT] Thinking about this some more and unless I missed something, Bama's method would require 6 valve changes to go from pool to spa or back? I'm not sure why you would want to do that. Valves C and F are necessary to make a change over easy. However, you need to isolate the spa and pool side on either side of the 3-ways.
    Mark
    Mar 2007
    Coastalish 'down easter'
    4,160
    Valves aside, unless the SWCG will know to turn down it's output in spa mode, you might want to only plumb it into the pool return line
    Luv& Luk
    -Ted
    Sep 2008
    The Woodlands, Texas, USA
    243
    I assume you are planning on a variable speed or at least 2 speed pump to run pool circulation and spa jets?
    Otherwise you may want to change what is on the diagram to read SPA RETURNS (instead of jets) and put the jets on a separate system/pump.
    Just FYI: My Goldline PS-8 will accomadate 2 different settings for the SWG for pool or spa mode.
    Its nice to place a return over any shallow steps, sun tan ledges when possible to help blow debris off of them as some cleaners like my Polaris 280 cant get into shallow areas less than 18" deep very well.
    Lee
    IG 24k plaster with overflow spa. Goldline PS-8 SWG. Tristar 0.75 HP filter pump, Polaris 280, large cartridge filter, 400k BTU NG Max-E-Therm HD, SR Smith Turbo Twister, Life Saver pool fence, ORP managed.
    Vero Beach, FL
    462
    Thanks for the tips. My pump is a Max Flo II single speed that delivers 50 gpm at 50 ft of head. The spa has only 4 Hayward Pulse-Flo Rotatable Nozzle jets which requires 10 gpm each. The pump is relatively close to the spa, the lines are 2", and the PB used minimal fittings. I think I'll get the force I want. If not, I can always upgrade to a 2 speed pump and the PB said he will give me credit on single speed pump.
    Solar heat
