Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: "Don't run SWG at 100%"...Why?
    May 2009
    Rocket Town, AL
    49
    Hi all,
    I've seen mentioned several times that one should NOT run their SWG in the "Super Chlorinate/100%" mode.
    But I can't recall why....anyone? My pool builder recommends hitting 100% once per week.
    Thoughts?
    18x36 In-ground Vinyl, 24,000 gallons.
    Sand Filter, 1hp Hayward.
    SWG
    Polaris 280
    30,414
    Re: "Don't run SWG at 100%"...Why?
    The higher you run the SWG, the shorter the cell life.
    You should disregard your builders advice for the 100% weekly. In a well maintained pool, there is no need.
    If he's suggesting that to shock the pool, bleach is far better in it's effect and, in the long run, cheaper probably.
    Butterfly's Avatar
    South Carolina
    10,045
    Hi PhotoEd,
    Welcome to the forum
    In addition to what Davd said, you might want to check out our Pool School article on How to Shock Your Pool.
    The last paragraph has more info concerning SWGs....
    There is also an article on Water Balance for SWGs.
    You're done SLAMing when:
    May 2009
    Rocket Town, AL
    49
    Thanks gang, I just wanted a straight answer why some people here said "Don't do it". I always saw the advice, just not the reasoning behind it. But I guessed correctly.
    Agreed, I haven't had the need to shock a single time all summer...
    SWG
    Polaris 280
    Jul 2007
    Brisbane, Australia
    874
    you can run it at 100%, just not 24/7
    superchlorinate mode usually just puts it at 100% for 24 hours and then reverts back
    May 2009
    Rocket Town, AL
    49
    Correct. But why run it at 100% at all? Or back to the original question, why do folks on here say "don't do it at all"?
    What is the benefit of running at 100%, if not to shock the pool?
    SWG
    Polaris 280
    Jul 2007
    Brisbane, Australia
    874
    benefit is that you reduce your pump run time -> less money spent on electricity
    i don't know why people say don't do it at all, it doesn't matter too much whether you run your SWG 8hrs/day at 100% or 16h/day at 50%, but it does matter when you run it 24/7 at 100%
    the reason why most people advise not to use superchlorinate button is because it doesn't really do proper shocking, unless you have a huge unused capacity in your SWG (i.e you usually run it at 10% 4h/day)
    and it does wear out the cell more
    so it's cheaper, better and faster to just add some bleach when you want to shock
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Quote Originally Posted by PhotoEd
    Because bleach raises the chlorine level much faster than an SWG can in a short period of time, and if you ARE trying to shock, you likely won't reach shock level using the "boost" or "superchlorinate" feature at all. Also by not using it you will get more useful life out of the cell for daily chlorination.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    Super chlor is not the same as shock...
    You cannot shock your pool with a Cl gen with much effectiveness. Like FPM said, the unit cannot make enough Cl fast enough. The way i understand it, A perfect shock would be for the water to be instantly very high on Cl. This really isn't possible, so we settle for very fast (the time it takes to pour it in), and you just can't get the speed with a Cl gen.
    Did that make sense?
    Factory Warranty Station for:
    May 2009
    Rocket Town, AL
    49
    It does.
    SWG
    Polaris 280
    What percentage / run time would offer the longest life for the cell with chemicals levels properly maintained for a swg? The minimum run time for the pump is to turn all the water in the pool once a day, so should you adjust the output to maintain 4ppm FC? Would there be any measurable benefit to running the pump longer with a lower percentage or vice versa? Does anyone know what goes bad in the cell?
    Michiele
    Newbie pool owner
    25,000 gallon inground, vinyl lined pool, sand filter
    Jul 2007
    Brisbane, Australia
    874
    the precious metal coating on the plates wears out
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Quote Originally Posted by gregs
    0% (OFF) would offer the longest life; perhaps the best answer is to operate the cell at the lowest possible setting for the shortest possible time period while still achieving minimum Free Chlorine for your pool. In a trouble-free pool (no algae, < .5 chloramines) that could mean 10% for an hour or two... or 75% for 8 hours. Lots of variables affect the optimal setting/hours of operation.
    As you probably already know, 1 turnover per day is just a rule of thumb, not a commandment. Some pools need more than one turnover, a few can get by with less than 1 turnover. Many things have an impact on whether a given level of chlorine will work for your pool: Water temperature and balance, bather load (activity), water features, environment (eg. trees, pollen, dirt), use of solar cover, pump time, etc. Reference the guidelines in Recommended Levels in Pool School and then experiment with the time setting on your SWG until it works to maintain the FC that you wish to target. In general, aim for a chlorine level at least 5% of your CYA. (If CYA=50, Free Chlorine should be 2.5 ppm or more.)
    The pump almost certainly uses more electricity than the SWG; therefore, there may be a cost advantage to increasing the % and reducing pump operation time. But (just to complicate your decision a bit!) there's also a potential benefit to doing the opposite -- extended pump time and lower SWG % -- because the pool water, while exposed to the same amount of chlorine in a 24 hr period, will have the chlorine being produced when it's most needed (say, during the day in sunlight.) That's why some pool owners schedule multiple run-times, to replenish chlorine that's been consumed by UV light or otherwise spent due to oxidation of contaminants brought in by swimmers.
    Sorry, it's not really that complicated...
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Thanks for the answers. I guessed there was some type of plating on the cell that is slowly consumed.
    Its a new pool and I will start to adjust run times and % adjustment until I figure it out. Currently have been running 2- 4 hour times. 1 in the morning and 1 in the evening and the pool has been looking great. Have been using bleach up until this point and added salt yesterday so I can now turn the SWG on and see what happens!
    Michiele
    Newbie pool owner
    Jan 2009
    Cupertino, CA
    1,966
    I've been told that cell life is measured in amp-hours, which you can think of as percentage times run-time. So, 10% for 10 hours and 50% for 2 hours are the same as far as cell lifetime goes.
    --paulr
    BBB "Intermediate Swimmer"
    Does the cell produce continously whenever it is switched on? Or can it regulate the output. I was monitering my aquarite unit today and noticed times when I would go into the diagnostic menu and it would read 0.00 amps even though it was powered on and the generating light was on. Then I would come back a little later and it would have a 3-4 amp reading like it was working. It was set at about 50% power and had a salt reading of 3300. Is this normal? Can anyone explain how it works on a normal basis. Thanks
    Michiele
    Newbie pool owner
    polyvue's Avatar
    Aug 2009
    1,215
    Everything you describe sounds like normal operation. 50% power means that about half the time the cell will not be drawing electricity, so that explains the 0.00 amps. The salt reading is good. Just measure (test) the chlorine often in the first few weeks so you know if and when you need to adjust the control. On my pool (14K gallons, 3 hr pump time, cover in use), the chlorine level would quickly rise with a 50% setting, but yours may require it.
    __
    Jul 2007
    Brisbane, Australia
    874
    it depends on a model
    with some 50% output means that it's on 50% of the time within a given interval (say 5 mins)
    with others it means that the cell actually gets 50% of the power, say 12V instead of 24V
    Sep 2009
    9
    Quote Originally Posted by Strannik
    This is correct. The salt cells have a coating of Ruthenium (sometimes Iridium too) on them and it wears off when the salt cell is generating. So naturally when it is at 100% it uses up more of its Ruthenium than if its at 20%.
    Gilbert, Arizona
    30,000 gallon IG Salt Water Pool
  20. Back To Top    #20
    New2Me's Avatar
    Jun 2008
    SW Indiana
    322
    So, the precious metal is what causes the reaction? I thought that it was the electrical magic, and that the coating just protected the base metal, and maybe "enhanced" the magic. After all, if the base metal is titanium, isn't that precious by itself? Most junior science electrolysis experiments call for the use of two pieces of metal(usually spoons), with out regard to content. How much performance increase does a coating give, or is it a plate life prolongation?
    22 x 40 IG vinyl lined, 23,570 gal.
    1 hp. Pac-Fab Challenger pump 300# sand filter
    Intex 8110 SWG, Hayward CL220 offline feeder
    Hayward 250K Btu gas heater
    Aquabots
