Thread: Quick little question.... Tropical Storm related...
    pitguy3's Avatar
    Jul 2009
    Birmingham, AL
    156
    We have been visited by Tropical Storm Claudette and I have some questions... While we received about 1 inch of rain, we also has a lot of leaves and pine straw blown into the pool... I made sure, last night, that I upped my chlorine a tad to 6ppm instead of 5 due to the rain issue... Anyway, I just checked and there was a lot of "stuff" on the bottom... I got it out to waste and it looks good, but should I do anything, like shock it, because of all the debris? Here are my numbers as of 7pm tonight...
    FC- 3.5
    CC- 0
    TA- 130
    ph- 7.5
    CYA 55
    Thoughts??
    Also, I went by the Pool Store the other day to get a part and told him about me converting to Chlorine... He said that I STILL needed to shock at least once a week... Is that true??
    Thanks in advance!!
    Mike
    Intex 20x52 above ground pool-
    8632 gallons
    1 man 4 woman Bullfrog Hot Tub
    http://www.flickr.com/photos/pitguy3/se ... 763801706/
    ROLL TIDE!
    TravisD's Avatar
    Jul 2009
    Tampa, FL
    142
    Re: Quick little question.... Tropical Storm related...
    It's my understanding that you do not have to shock unless you have CC present.
    24' Round AGP | 13,600 Gallons | Waterway Cartridge Filter | Waterway 2 Speed Pump | K-2006 Test Kit
    100% Trouble Free Since The Baqua Conversion
    You only need to shock when there is obvious algae, the CC level is above 0.5, or FC goes to zero. When FC falls below the minimum you should add some extra chlorine, a bit above the target level, but there is no need to shock as long as FC didn't fall to zero and the water is still clear.
    pitguy3's Avatar
    Jul 2009
    Birmingham, AL
    156
    Cool... So far after my conversion, I have tried to keep the CC's around 5 and the water is still sparkling... However, yesterday while we were swimming, I noticed some "flakes" floating around... Nothing in the skimmer or anything, but... Any ideas what it might be??
    8632 gallons
    ROLL TIDE!
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    I hope you meant cc's of .5?
    Flakes? Describe them.... it could just be residual debris that hasn't been caught by the filter.
    pitguy3's Avatar
    Jul 2009
    Birmingham, AL
    156
    OOps... You are correct... I try to keep my FC's at 5 and my CC's at ZERO... Tonight my FC's were at 3 and CC's at .5 before I bumped it back up to FC of 5..
    8632 gallons
    ROLL TIDE!
