Results 1 to 9 of 9
Thread: Kids exiting Above ground pool
    Guest
    Quick question for anyone with Above Ground and kids (probably lots of folks!). I have 2 grandsons that want/like to climb out of the pool instead of using the stairs. I am in the process of building a deck all way around the pool.
    Is this a problem? The kids are 6 and 8 and weight is approx 50 and 60 bs respectively. I am trying to discourage this and have them pretty much broken, at least from standing on the rail to jump in, they consistently jump from the deck now.
    Thanks for info.
    Edd
    TravisD's Avatar
    Jul 2009
    Tampa, FL
    142
    Re: Kids exiting Above ground pool
    I certainly wouldn't allow that. I don't think the rails are meant to support any weight. Have you ever seen a full AGP without the top rails on it? It's kind of scary looking. There really isn't much there to support any weight. I think trouble is on the horizon if it continues.
    24' Round AGP | 13,600 Gallons | Waterway Cartridge Filter | Waterway 2 Speed Pump | K-2006 Test Kit
    100% Trouble Free Since The Baqua Conversion
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    I think it depends on the pool. The manufacturer should have specific recommendations. Our toprails can support my weight (and I'm not light ....)
    kilika2003's Avatar
    May 2009
    Toronto, ON
    48
    I think it's generally a bad idea with most above ground pools. My whole neighborhood has heard me "educating" my kids and other people's kids not to hang on the wall or to be careful to make sure they are standing on the deck,not the top rail.
    We do not allow jumping into the pool from the deck. I think there is mixed opinion on this. Should we or should we not be doing this, and if not, is it because of the movement of the water causing pressure on the walls? Or because of the potential damage to the liner? Obviously jumping from the siderails is a no-no.
    15' x 24' x 52" Buttressfree Concorde (Atlantic) ABG installed 2007, Hayward Sand Filter, Hayward 1 speed Pump, Royal Entrance Steps, Clear Solar Blanket, New Deck, and maybe soon a heater.
    Riles_J's Avatar
    Nashville, TN
    218
    I would say a lot depends on the pool. We had an above ground pool growing up, and my folks tried to keep us off the sides, but we were probably like a lot kids and we weren't so good at listening . We would walk around the sides, jump off the sides, have jousting matches, etc. These were junior high and high school boys BTW so they where put through the wringers. I am certainly not saying that this behavior should be tolerated, because now that I have 3 kids of my own I am quite certain I would be trying to thwart this type of behavior I am only stating this because after all the abuse that we put that poor pool through we never had any issues with the rails, sides, etc. I have to believe most pools are meant to withstand a good deal of this behavior.
    Riles
    16x32 IG vinyl, 19,000 gal, 1.0 hp pump, sand filter, 2 returns, 1 skimmer, diving board, slide
    Aug 2008
    Conway SC
    102
    Quote Originally Posted by frustratedpoolmom
    LOL 220lbs and I use to do it all the time untill this season.. Not to jump in but I walked around it to vacuum..
    17000 Gallons (16x32) Vinyl In Ground Pool
    Sand Filter
    Install "Finish Date" July 30 2014"
    Propane heater installed.. Used for 1 day.
    City Water.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Standing on the top rail isn't really an issue, Unless the pool is damaged from age or showing wear it can easily support an adult standing on the top rail. Regardless I wouldn't recommend it just in case. The real issue here is the process of climbing out of the pool without using the ladder or steps. This is what causes crecent moon shaped slices on the slide of the pool wall in the vinyl. Even clipped nails will dig into the vinyl and can cause puntures, make sure they use the ladder
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Pool integrity is not an issue here - our pool manufacturer used to have a video on line where they stirred the pool up with the arm and bucket of a big backhoe without uprights and rails - stir was an understatement!
    Uprights and rails don't do anything for integrity - well, on oval pools the side uprights and buttresses keep the sides from pushing out to turn it into a round pool, but round pools have their load equally distributed already and do not need any kind of support, the uprights are really just to hold the top rail and the top rail only exists to protect the top edge of the wall - without it you risk damaging the wall structure if pressure is applied.
    Our pool has roto molded uprights and top rails that are super strong - I have no problem with my kid climbing out over the wall, however, if it were aluminum or metal - I'd have my doubts since it dents easily and takes away from the aesthetics of the pool over time.
    When my kid climbs out - I've taught him to steek clear of the wall - he just swings a leg up and on top without "clawing" the wall.
    Jumping into an AG pool is fine - I have a platform for it - but diving is a nono.
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Well, will it damage your house if you climb out the windows? Are they meant for that? You can, but the question is should you? If you have steps or a ladder then it should be used for that purpose. Kids can get injured standing still, why increase the risk with climbing out of a pool on the wall? Steps/ladder: One less way to cause damage or injury.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
