Thread: Refilling a fiberglass pool
    I just drained and refilled my fiberglass (over plaster) pool because the CYA was very high. Should I follow the start up procedures for new plaster pool or something else? Here are the current numbers.
    FC 1.5
    pH 7.5
    TA 30
    CH 40
    CYA <30
    30,000gal. IG pool - applied fiberglass over gunite when pool was remodeled, cartridge filter, 1HP pump, 100 gal/min flow rate
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Re: Refilling a fiberglass pool
    If the plaster is old and cured well I would think you just follow procedures like you were opening the pool for the first time for the year. Just make sure your water is balanced and you should be good to go!
    Love TFP? Become a
    TFP Supporter!
    30,432
    It sounds like you have a fibreglass pool, regardless of what's underneath.
    Fill 'er up! You need more chlorine in there than you currently have. at least 3-4ppm.
    You also need more CYA.....at least 30-40ppm.
    Post back if you need help with how much to add.
    Welcome to the forum.
