Thread: return issue
    return issue
    I have been running my pump 24/7 to battle an algae problem and notice today that the return furthest away from the pump is not returning water the return closest is working just fine...if I shut the pump off and turn it back on the far return starts working for a few minutes then stops while the near return still works fine any ideas?
    24k IG (plaster) Triton Sand Filter
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: return issue
    Any air coming out of any of the returns or in the pump basket? How is the pressure on the filter?
    Re: return issue
    i shut the pump off and released the little bit of air that was in the filter and all jets have been working for about 8 hrs now i will keep an eye on it and post if anyting changes thank you for the response
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: return issue
    Can you remove the inlet fitting and see if something is stuck in the 'eyeball' that blocks the inlet?
    Luv& Luk
    -Ted
