Thread: pH or Alkalinity
    Aug 2009
    Bradenton, Florida
    11
    pH or Alkalinity
    What's more important to correct when your pH is 8.0 and alkalinity is 80? Also, will sulfuric acid reduce pH while leaving alkalinity stable?
    8 K pool, cc 100 filter, Auto-Pilot SWG, 1 HP Whisper-Flo pump, in-ground gunite pool 9 yrs. old,solar heat and Pentair 250K heater.
    30,421
    Re: pH or Alkalinity
    Use muriatic acid to lower your pH down to 7.4-7.6. I'd do that pretty quickly.
    Then, test your TA again. If it's below say around 70, you can bring it up with baking soda. The baking soda will have little effect on the pH.
    You can use Jason's calculator in my sig.
    Ask any questions you may have. Lots of nice people here to help.
    Aug 2009
    Bradenton, Florida
    11
    Thanks, but doesn't a low TA require bi-carb, and a low pH soda ash?
    Jan 2009
    Cupertino, CA
    1,966
    Baking soda = sodium bicarbonate, raises TA without much effect on pH.
    Soda ash = sodium carbonate, raises both pH and TA.
    Borax (as in 20 Mule Team) raises pH without much effect on TA [included here for completeness].
    --paulr
    BBB "Intermediate Swimmer"
    Butterfly's Avatar
    South Carolina
    10,045
    Hi jaybo500,
    Recommended TA for SWG pools is 60 to 90, so yours is right in line.
    Here's our Pool School article for pool-school/water_balance_saltwater_generator
    Welcome to the forum
    You're done SLAMing when:
