Results 1 to 10 of 10
Thread: New pool owner
    New pool owner
    OK so we just got this summer cabin that was my husband grandfathers. It has a 18' diameter pool they said they normally kept it at 4-5 foot deep. It has not been used in multiple years. We went up to check it out last weekend. Pulled off the winter cover to find algae. I took a look at the filter that they had and I am a little stumped. It is a metal container, they said it was a sand filter. But I do not see a lever to switch from filtering to backwashing? It has the name Lomart on it and they said they got it for free from a friend years ago. We are in a colder climate, so pool would only be operating for about 2-3 months Now for my questions.
    1. Should we just get a new filter, or if you think we could salvage the old one, where should I look to figure out how to work it??
    2. I looked up how to get rid of the algae, but I am not sure which chemical route would be best for us. We are willing to devote the extra time initially to clearing up the algae, but once it is clear we will only be at this summer home once a week, sometimes every 2 weeks. IS there a convenient way to clorinate the pool while we are not around, or should we give up hope of having a pool at the summer home because it would not be feasible to maintain it without being there constantly?
    18 Diameter pool 4ish foot deep... so about 8,000 gallons of water
    above ground vinyl liner, some really old metal sand filter with the name Lomart on it.
    Arizona
    924
    Re: New pool owner
    Sorry, cannot see your pics. It wants a log in or says the pic has been moved.
    There may be a lever that you twist and pull up to switch from filter to backwash.
    I think your best bet would be to invest in a salt water generator, but frankly, unless you are going to have someone around at least once a week or so to check on your pool, you are really gambling.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    30,419
    Re: New pool owner
    The odds of you being able to maintain a pool with visits that infrequently are not good.
    Given your short season, it hardly seems worth the major effort it would be. That said, it can be done but you will need paid help, I think.
    Arizona
    924
    Re: New pool owner
    This also may be the case where sticking with trichlor tabs and dichlor shock may be the way you should go. Keep a large floater with pucks going. You may need to plan on dumping most of your water every swimming season because of increasingly high CYA levels.
    Buggs
    Re: New pool owner
    Thank you all for your comments. We went to the pool place and they said that it was possible to go about 7-10 days between clorination using a self chlorinator with slow releasing "pucks". So we are going to give it a shot.
    Re: New pool owner
    You are going to leave a filter running unattended for 9 months? Did I misunderstand, summer cabin up north, swimming for 3 months maybe. Do you visit every week all year or just summer?
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    Re: New pool owner
    I'm assuming the pool will be closed for 9 months, and open for the other 3.
    40 x 16 IG Vinyl. Goldline SWG
    160 Sq Ft Roof mounted solar array
    2014 Hydropool Serenity 5000 Hot Tub
    The Pool School- A great place to start
    Jason's Pool calculator
    Re: New pool owner
    Quote Originally Posted by Molson
    Forgive me, I'm in Texas. By closed, do you mean, power off, covered up, winterized, etc? I understood from reading that no one keeps a floater with pucks in it for the winter.
    So, are you talking about summer usage? As in, opened in the early summer, partial drain if necessary, shock to rid algae, get all chems in balance before swimming, and then visit every week or two at the cabin and maybe swim then?
    Um, 3 months. With an automatic chlorinator, I'd probably try that. Shock before leaving with cal-hypo or bleach, fill the chlorinator with pucks and cover it up as you go. Certainly good for a week, maybe two, I'd guess. Not sure about whether it is wise to run or not run the filter when no one is there for 2 weeks but the local authorities will know better I suppose.
    Re: New pool owner
    ah yes, we are going to winterize the pool and bring the filter into the cabin for the winter. We are up in Buffalo, so the winters definitely require it. Pool time around here is normally open mid-late may, and close in beginning of september.
    "So, are you talking about summer usage? As in, opened in the early summer, partial drain if necessary, shock to rid algae, get all chems in balance before swimming, and then visit every week or two at the cabin and maybe swim then?"
    Yep this is exactly it.
    For running the filter while we are not there, we are going to get a timer, the pool guy said to run for eight hours at night, does that sound long enough, or do you think we should run it more than that.
    Also if anything went totally wrong, they are close with the neighbor across the street, he checks in on the property and mows the lawn, so I am sure he would notice it. (we just didn't want to ask him to take care of a pool for us too, because he has already done so much for them)
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: New pool owner
    I think you can make it work, the main thing with having the neighbor be able to check on things is a real plus - just have him make sure the water level is up and the pump is running "normally". I think 8 hours a day is probably good but I would make sure there are some daytime run hours - to help prevent FC dead spots - try 4 hours daytime and 4 hours night time.
