Thread: Does anyone have Vortex Solar Pool Heaters?
    Shelley N's Avatar
    Denver, Colorado
    199
    We need to replace our hail damaged solar panels and need 4' x 8'. Does anyone have Vortex Solar Pool Heaters? http://shop.solardirect.com/index.php?cPath=21_34_38_48
    I can't tell for sure, but I don't think they are the standard nipple header assembly most others are and the header is 2" instead of 1.5". We currently have the style with the bypass on one end which makes the water travel up one side and done the other. These will be in one end and out the other so I'm hoping for more water flow thus more heating. The only other ones I can find are 1 x 8 that come in sets of 4 you plumb together. Maybe easier to replace if one starts leaking, but I'm hoping the Vortex are beefy and last longer.
    Thanks.
    Shelley
    Denver, CO
    Shelley N's Avatar
    Denver, Colorado
    199
    Re: Does anyone have Vortex Solar Pool Heaters?
    Ok, wrong question. Does anyone like the look of Vortex panels? Don't they look beefy!?
    Shelley
    Denver, CO
    el_steak's Avatar
    Aug 2007
    Ottawa, Canada
    110
    I think they are the same panels as the ones from TechnoSolis (which I have). The instruction sheet that came with my panels had the word "Vortex" left in a few spots. I also have the larger 2 inch headers, although my pool plumbing is only 1.5 inches.
    Instead of being a bunch of small pipes attached together like most panels, they are completely flat and have square channels in them.
    I don't know if they are more efficient or more durable than other panels, but so far so good with mines (2 years only).
    Here's my installation:
    solar-panel-installation-pic-t5823.html
    14X24 ig vinyl pool 3ft-4 1/2ft deep - 7000 gal
    Aqua Genie skimmer and return - no main drain, 1 hp hayward pump, 27" Hayward filter with Zeobrite,
    Aqua Logic P4 controller + SWG, 2 lights
    192 square feet of solar panels controlled by P4, 5KW electric heater (just in case...)
