Thread: Balanced or not or maybe?
    SCCS's Avatar
    Sep 2008
    Left coast
    Just a little confused on the different way's to see if the water is balanced or not.
    My pool readings: 3 fc
    7.4 ph
    100 ta
    360 ch
    90 cya
    3950 salt
    If I go with the "Pool Calculator" it tells me it is at -.33.
    If I go with the "Langelier Saturation Index" it tells me it is at 0.
    And if I use the wheel that came with the Leslie test kit it tells me it is at 0 also.
    Pool is cyrstal clear but has a little scale comming from the swg when it does a cleaning cycle.
    Is -.33 close enough to consider the water balanced or am I doing something wrong?
    16,500 gal Roman end with PebbleFina finish
    4 x 160 intelliflo pump
    Easytouch controls with an IC40 chlorinator
    Sta-rite cartridge filter
    A & A infloor cleaning system
    Pentair 5g LED pool light
    Re: Balanced or not or maybe?
    You are fine. You don't need to worry about the saturation index unless it is way off. Lowering TA just a little would be a good idea, both to reduce the scale coming off the SWG and to help stabilize the PH.
