Results 1 to 9 of 9
Thread: New Pool with Nutgrass growing through liner
    Huntsville, AL
    26
    Hi,
    When we had the pool insalled last month the installer recommended spraying the area with nutgrass killer so we did. Even taking all that precaution, yesterday while swimming I noticed two places on the cove where nutgrass had grown through. I didn't pull them yet until I could ask the experts here how to handle this situation.
    So should I go ahead and pull them out of the liner and put a patch over them? I'm afraid they well just grow back through the patch.
    Or should I spray the area with more killer and let them die without pulling them?
    Anyone else had this proble and how did you resolve it?
    YBnormal...have a pool
    15' x 30' Beachland AG Pool (12000 gal.)
    Hayward 1 HP Power-Flo LX Pump
    Hayward 18" Sand Filtration System
    Bob_Funk's Avatar
    May 2009
    Seattle-It really rains all the time
    113
    Re: New Pool with Nutgrass growing through liner
    I have never heard of it before, but after googling, it appears nasty.
    have you read this link yet?
    http://www.green-seeds.com/PDF/nutgrass_control.pdf
    I consider myself very lucky I found this site before the pool store found me-pool owner since Nov 2008- Stunningly clear 17,000 gal fiberglass pool, thanks to this site, installed in 1982-24" 3.1sq. ft sta-rite sand filter, 1 hp - 2 speed wisperflo pump-WFDS-4
    Aug 2009
    Central PA
    64
    I'm guessing that the grass is somehow growing between the cove and the actual liner... I know the grass is tough, but I can't imagine it is actually pushing through the vinyl... or is it?
    Anyway, maybe if you post a pic it would help folks diagnose. Have you talked with your installer yet?
    Regarding nutgrass elimination, there's a product, SedgeHammer, that is effective and won't kill your lawn. I think it works better than RoundUp.
    29,000 gal. vinyl in-ground mountain lake (freeform); Hayward DE filter, 2 skimmers, AutoPilot SWG, 2 - 4 X 20 Fafco Solar Bears with Goldline control, Aquabot, LoopLoc winter cover, Pool installed March 2009...
    22,542
    Nutgrass is terrible stuff. It'll grow right up through the liner. If it's close to the edge you could inject herbicide under the soil and liner and kill it then patch the small hole the shoots leave.
    Nutgrass will indeed grow through a liner. Do NOT pull it out until you are ready to patch it... the weed will keep the hole basically plugged up!
    8200 gallon 20' x 48" round vinyl frame pool, manually chlorinated with 10% liquid, salt added to ~2000, 12" sand filter, 1600gph pump, TF100 test kit
    Huntsville, AL
    26
    Thanks for the replies, I didn't want to pull it out and leave the hole without a patch in hand. I think I will try as suggested and try to inject some herbicide through the rocks and under the liner to kill it before I pull it out, otherwise it will just grow back through.
    What do you use to inject herbicide under the edge of the pool?
    12' x 24' Rectangular IG ~10,000 gal, plaster
    1 HP pump, 4 cartridge filter, AquaRite SWG
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    At some point, if it gets bad enough, you may want to put down Gorilla Pad, I believe they claim to prevent nut grass from getting thru.
    22,542
    You can use a pump sprayer. Be sure to get pre-emergent herbicide that is stated for nutsedge. Just take a rod and make a hole in the ground angled under the pool and stick the nozzle in it, and saturate the ground good. You'll need to do that many places around the pool. Then just patch the holes after the grass dies.
