Results 1 to 12 of 12
Thread: Out of wack forgot my readings!
    Aug 2009
    Costa Mesa, CA
    8
    Balancing our out of wack SWP
    My husband is new to caring for our 10,800 gal quartz SWG pool - we have a Pentair Intellichlor, a Pentair IntelliFlo4 160 and a FNS P60 Vertical Grid DE filter. We've been having a recurring battle with the mustard algae and scale on the SWG and when you see our readings you'll understand why! So glad I found this website!! We bought one of your test kits (salt sticks too) and we did the calculator. I need to know what order we should things - do we should start at the top of the calculator with adjusting the FC, then PH, then TA down the calculator chart or should start by adjusting the salt, then the CYA then the TA etc as instructed in the "Water Balance for SWG's"? Keep in mind we are having family over tomorrow- Sunday about 1pm to swim!!
    Thanks for you help with this!!
    10,800 gal Quartz pool with attached spa
    Pentair Intellichlor-IC40
    DE Filter: FNS P60 Vertical Grid
    Aug 2009
    Costa Mesa, CA
    8
    Merged. Butterfly
    10,800 gal pool
    FC:2
    pH: 8.2
    TA: 140
    CH: 570
    CYA: 50
    Salt: 2900
    CSI: .96
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Out of wack forgot my readings!
    Welcome to the forum
    First, adjust your pH down to around 7.4 ASAP.
    What is your CC or TC test result?
    You're done SLAMing when:
    Aug 2009
    Costa Mesa, CA
    8
    didn't do the cc or tc. will go do it now!
    Aug 2009
    Costa Mesa, CA
    8
    My cabana boy husband did run them!
    cc is .5 and tc is 2.5
    Aug 2009
    Costa Mesa, CA
    8
    OK the CC is .5 and the Tc is 2.5.
    My husband says the SWG bbok says to add no more that 16oz of bleach at at time and the pool calculator is calling for 25 oz - what should we do?
    Aug 2009
    Costa Mesa, CA
    8
    Balancing our out of wack SWP - Husband added PHOSfree!!
    I'm in here trying to get answers my husband is out there trying things! Pool store sold him some PHOSfree he added about 25oz of it - mustard algae is gone just like that. I hope that stuff isn't bad for the pool!
    FC: 2
    pH: still 8.2 after adding 16 oz 12.5%. Husband is going to add 16 more oz but Pentair book says to add no more than 16 oz per day!!!!! should we keep adding it?!
    TA: 140
    CH:570
    CYA: 50
    SALT: 2900 he is going to add 40 lbs salt now.
    CSI: .96
    What next?
    We have a pool party tomorrow is it ok to add stuff today?
    Thanks!
    Aug 2009
    Costa Mesa, CA
    8
    Re: Balancing our out of wack SWP - Husband added PHOSfree!!
    oh yeah: CC is .5 and TC is 2.5
    Adding more acid is fine. You want to be careful not to allow the PH to go below 7.2, so you don't want to add the full amount all at once. But you can add some acid, wait 30 minutes, test the PH, and then repeat.
    PhosFree will sometimes cause the water to get cloudy, but if that hasn't already happened it won't be a problem.
    Aug 2009
    Costa Mesa, CA
    8
    where does the phoshorous come from? Once we get the pool balanced will we continue to have an issue with it?
    30,414
    Can't answer about the phosphorous.
    Have we determined how your water looks? I just brushed thru the other posts and saw no mention of water clarity but there must be some visible problem...right?
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Quote Originally Posted by Salt H20 Pooler
    Not really sure where the phosphates come from, but I would assume from your fill water. In a properly balanced and sanitized pool, phosphates aren't an issue. Several members on here such as JasonLion have high phosphates in their pool, but have no problems at all from them. The PhosFree your hubby added really wasn't needed.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
