Thread: Slightly dull water
    Fayetteville, Arkansas
    220
    Slightly dull water
    Here are numbers from about 10 minutes ago.
    FC 1.4 (low, today is my 'add' day)
    CC 0.0
    Ph 7.6
    TA 90
    CH 70 (low - this number has been dropping)
    CYA 40
    I've somehow lost the shimmering sparkle. Borates - which I don't know much about - would help, yes or no???
    We've had lots of rain lately too.
    Hope everyone's summer is going great !! !!
    20x40 30,000 gal IG Liner, Pentair II Sand
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    I usually try running the filter around the clock a few days if that happens.
    220
    During the season - I run my pump 24/7. I think it may have clouded due to running my vac - lots of rain and the labradors have been in the pool more than we have ... dirty dogs !!
    30,431
    Re: Slightly dull water
    Rangerman,
    My bet is if you bring your FC level up to about 15-18ppm and let it drift down of it's own accord, your pool will sparkle again. It sounds like your letting your chlorine slip below 3ppm and I believe you have some organics growing in the pool. Shocking will kill them. (I see your CC's are zero....I'm still suggesting to shock)
    Recheck your testing method on Calcium Hardness. Once in the pool, calcium is a permanent guest....you should see no drop in your Calcium tests.
    Just to throw another observation in to the mix, I've noticed that I tend to lose that crisp liquid glass sparkle when my PH gets to 7.6 or above. I noticed it today, tested PH, it was 7.6. I just hit it with acid.
    gonefishin's Avatar
    Joliet, Il.
    413
    Hi there,
    I've also noticed that when my Ph raises to 7.7 or higher I start to get a little cloudy. But letting the chlorine drop that close that low I don't think you could go wrong with a shock.
    good luck,
    dan
    33' Aqua-Leader AGP
    Hayward cartridge filter and IntelliFlo VS pump.
    Solar Heat coming ; used to own Aqua-Cal HeatWave 100k (HeatPump)
    Aqua-Rite t-15 SWG
