Thread: DE not sticking
    DE not sticking
    My inlaws pool needs dire help. I'm trying to help them out, I feel sorry for them because they are in their mid 80's and they cannot enjoy their pool. They have a hayward filter which for some reason the earth does not stick on the bottom 20% of the grids. It seems that there are some kind turbulence that is not allowing the earth to stick. When they first turn on the pump some earth is leak out to the pool and when they vacuum the you can see junk returning to the pool. I removed and inspected the grids/manifold/inlet oring around three times and I'm not making any progress. Thanks in advance! Glenn
    12200 gallons, ig vinyl, 1hp hayward super pump, hayward s244t sand filter
    X-PertPool's Avatar
    Exeter, PA
    Re: DE not sticking
    Unless I'm mistaken DE should not be able to make it through the filter to the pool unless the fabric on the grids is damaged. What you suspect as DE not sticking might be the area where the DE is passing through freely. I would replace the grids or the filter entirely.
    X-Pert Pool Service
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Re: DE not sticking
    Something is broken, else you would never see DE coming back into the pool.
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    Re: DE not sticking
    Thanks for the replies. The filter is only a year old and had the grids inspected twice by two other people. The only thing I did notice is that bottom intake tube inside the filter is loose. Last Friday, I tried to secure it by placing a plastic block under the pipe to keep it level and from rocking around. I also notice when they shut off the water pump, some of the water will drain back to the pool.
