Thread: HEAD PILLOWS Sweetwater/Sundance spa
    jwfrank's Avatar
    Oct 2008
    Todi, Umbria, Italy
    55
    I have head pillows purchased from the spa manufacturer (now Jacuzzi, I believe) that have developed blisters after only a year. I am careful about adding chemicals (bleach and acid) and chlorine levels are not high
    1/ Can anyone shed any light as to the likely reason for the blisters?
    2/ Recommendations as to where to buy good, durable replacements? Not necessarily from Sweetwater/Sundance/jacuzzi which are expensive, and obviously not long-lasting
    Thanks
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: HEAD PILLOWS Sweetwater/Sundance spa
    Do you mean you have blisters on your head where you rest it against the pillow? If not, then I'm not sure I see the connection.
    I assume that he means that the plastic is blistering.
    Mar 2007
    San Rafael, CA USA
    12,082
    Doh!
    jwfrank's Avatar
    Oct 2008
    Todi, Umbria, Italy
    55
    Yup, the pillows themselves have blisters. Trying to find out why
    Thanks
    jerrypar72's Avatar
    Nov 2007
    Phoenix
    32
    The 8 year old pillows on my Sundance Caprio ST spa are now in pretty bad shape. The best deal that I found for replacement pillows was online at www.spaandpoolstore.com. I ordered the 3 pillows yesterday for $140.00, while the local Paddock pool store wanted $225.00 for the same pillows.
    11,000 gallon Tahoe blue pebble tec, PCC 2000 in floor cleaning system, with two Pentair 1.7HP cleaning pumps, and a separate pump for water feature, Frog chlorinator, 60 SF DE Filter
