Results 1 to 17 of 17
Thread: What to use to gather test sample
    crewchief47's Avatar
    May 2008
    Windsor, ON
    60
    split to new topic by Moderator - MikeInTN
    Quote Originally Posted by frustratedpoolmom
    rinse with tap, wipe with paper towel (FAS-DPD vial). Rinse with pool water before performing test.
    OTO/PH air dry.
    This is eerily similar to my process. Do you bring a plastic beer cup of pool water into the house to do your testing too???
    Esther Williams 24', sunk about 36" into the ground.
    Jacuzzi Maxiplus 190 sand
    Sta-rite/aquatools 2 speed 1HP (JWP series)
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Cleaning testing vials
    Quote Originally Posted by crewchief47
    OTO/PH air dry.
    It's a kiddie cup from Famous Dave's BBQ....
    May 2009
    Enterprise, AL
    54
    OTO/PH air dry.
    Big Subway cup for me. I use a 4 ft section of 1/2" pvc to collect the water from about 18" below the surface so I don't have to bend over much.
    20K gal IG vinyl 18'x36' rectangle, 2' radius corners
    Hayward Goldline Aqua Rite 40K SWG, Pentair Intelliflow VS 3050,
    Sta-Rite Cristal-Flo 24" Sand filter, Model T-240BP-1, Polaris 280 Auto Cleaner
    Sunstar solar panels (438 sq ft ), Pentair Sun Touch Controller automating solar panels, SWG, and Polaris
    TF-100 test kit
    Jun 2008
    Scottsdale, AZ
    37
    I have a beer cup but it has beer in it not pool water. Does that count?
    Gary
    18 x 38 28800 gals gunite inground;Purex Triton High Rate Sand Filter;1 HP 2 Speed Hayward Tristar Pump; Raypak Heater
    Aquabot Bravo; Goldline Aqua Logic Controller/SWG
    30,432
    That is an excellent tip. I have had 1/2" pvc laying all around for years and I've never thought of that. My tired old knees thank you.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Mmmmmm....Famous Dave's. Used to eat there when I had to go to Janesville for work.
    Jun 2007
    Long Island, NY
    34
    Quote Originally Posted by FSI_C-12IP
    Can you be more specific about how you utilize the pvc to get the water sample?
    Brian
    18' round x 52" vinyl AGP holding aprox. 7633 gallons of crystal clear sparkling water, most of the time. Hayward s166t sand filter, 1 hp pump and 2-2x20 Fafco panels is parallel. TF100 test kit and BBB!
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Jul 2009
    S. California
    157
    Ah Man! I must be the only one reaching way down and getting my shirt sleeve and entire arm wet each night!
    18'x 52" Intex Ultra Frame AG pool
    7100 gallons
    1600 Intex sand filter
    TF-100 test kit
    BBB method for four seasons
    Former 18' Easy Set owner
    May 2009
    Dallas, TX
    785
    Quote Originally Posted by Livinright
    You are not the only one, but not for long...now where did I put that piece of PVC pipe...
    Great tip guys!
    Dave
    20K gal IG plaster pool, Manually chlorinated with bleach, 1.5 HP Sta-Rite Dura-Glas II pump, Pentair FNS Plus 48 DE filter, Polaris 280
    11,969
    Re: What to use to gather test sample
    I forgot to mention how tricky it is to gather my sample with one hand while holding my margarita in the other. I'm very talented...
    Jul 2009
    Blue Springs, MO
    105
    If you use the beer cup after you finish the beer, will that affect your readings?
    24'x4' AGP Round
    S166T Hayward Sand Filter
    S48K2A2 Hayward Pump
    May 2009
    Enterprise, AL
    54
    Quote Originally Posted by Macrosill
    Hold your palm tightly over one end and stick the pvc down into the water about 18" or so. Then take your hand off to let the water in and recap the pvc with your palm to hold it in. Oh, did I mention to set your sample cup close to the edge of the pool first? Sorry, do that and when you withdraw the pvc from the pool, you release the water into the cup. Kind of like playing with your soda with a straw!
    TF-100 test kit
    May 2008
    Windsor, ON
    60
    Quote Originally Posted by sgtdvldog
    You have to be careful to avoid 'sloshing' yourself or the sample. I even used a sharpie to label the 'Pool's glass so I don't accidentally pilfer the wrong brew.
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    pilfer a pilsner?
    Jul 2009
    Blue Springs, MO
    105
    Have to be pilfer...wouldn't want a glass pilsner at the pool.
    24'x4' AGP Round
    Jun 2007
    Long Island, NY
    34
    Thanks reebok and FSI. I am going to try that out.
    Brian
