Results 1 to 11 of 11
Thread: Hello From ND
    Hello From ND
    Hi everyone. I have been reading the posts on the site and decided to join. I take care of 2 pools the Park District in Grand Forks ND. One pool is 500,000 gallons and the other one is 256,000 gallons. We use bleach for the sanitizer and acid for PH control. Our season is short in ND the 2 pools are only open for 3 months. I have enjoyed the forum from reading the posts and hope to join in on the discussions.
    May 2009
    Dallas, TX
    784
    Re: Hello From ND
    WOW!!! How much bleach do those pools consume in a day???
    Welcome to the forum!
    Dave
    20K gal IG plaster pool, Manually chlorinated with bleach, 1.5 HP Sta-Rite Dura-Glas II pump, Pentair FNS Plus 48 DE filter, Polaris 280
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Hello From ND
    Hi SMH,
    We would like to see a pic of those gargantuan pools!
    I'm with Beez, how much bleach?
    You're done SLAMing when:
    Re: Hello From ND
    Thanks for the welcome. This year in the 256,000 gal pool I have used a high of 285 gallons one week and around 60 gallons on the low end for a week. We just got the big pool up and going last week after a 6 year hiatus. We used gas chlorine in that pool before, so I'm estimating that I will use twice the amount what the smaller pool uses.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Hello From ND
    So, um, like in jugs?
    Do you just have crates of the stuff? Or do you get it in giant tanks or something?
    Re: Hello From ND
    This year as of Monday I have went through 1200 gallons bleach, 220 gallons muriatic acid, 850 lbs sodium bicarbonate, 800 lbs of calcium chloride and 75 lbs stabilizer. The place where I buy my chemical from comes up with 325 gallons totes and pumps it in to my tanks. I have 2 300 gallon tanks and 3 225 gallon tanks that the bleach is stored in. The acid comes in 15 gallons drums, the sodium bicarb and calcium chloride come in 50 lb bags. I have a chemtrol 250 controller and stenner peristaltic pumps that do all of the work dosing the bleach and acid.
    11,969
    Re: Hello From ND
    Facsinating. Whenever I go to a public pool I'm always trying to peek behind the scenes to see "the set up". If I'm ever out your way I'm gonna PM you so I can have a tour
    30,424
    Re: Hello From ND
    I was just thinking about complaining publicly on the forum about my chlorine usage lately.......I think I'll keep my mouth shut
    Re: Hello From ND
    Quote Originally Posted by frustratedpoolmom
    tours are always free of charge
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Re: Hello From ND
    It's been a couple of weeks since you posted this thread, but I wonder what kind of challenges you encounter in managing such a large operation. Also, do you have a boiler to heat the pools? Use a filter to condition your make-up water? Welcome to TFP.
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Hello From ND
    Welcome to TFP!!
    I, too, have had the 'pleasure' of playing with large commercial pools :P
    Just from the amount of acid your using, it sounds like the alk may be a bit high - if you lower it you may get away with having to use less acid
    Luv& Luk
    -Ted
