Thread: SWG & pH
    Jun 2008
    NW MO
    185
    SWG & pH
    I was just reading the "Water Balance for SWG" once again and got to the pH recommendation of 7.5-7.6 - stating that this was important. I have been running the SWG since the middle of June and I added borates in the middle of June. Ever since my pH has been steady at 7.2-7.5 - usually closer to 7.2. I have not wanted to add to bring it up since my TA is already back in the 80-90 range (it rose back up after adding borates). I have not added any acid since I added the borates.
    Do I need to raise my pH to 7.5? or since it has been steady, can I just leave it at 7.2?
    24ft AGP 52in deep ~13,500 gal
    Hayward Sand Filter 250 lbs
    SWG
    1.5 HP pump
    425 gal stand alone QCA Hot Tub 15-20 yrs old
    dmanb2b's Avatar
    Apr 2009
    NY
    3,728
    Re: SWG & pH
    Hey there...we have the exact same situation, thereis absolutely no problem with your water being at 7.2 or slightly higher, as long as the PH is stable you are within the safe swimming range.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: SWG & pH
    Do you notice it goes lower when you leave the solar cover on? I do. You can also just turn the eyeball up and leave the cover off for awhile each day to help the PH rise back up.
    Off to the pool!
    Jun 2008
    NW MO
    185
    Re: SWG & pH
    Great!
    I have not noticed that it makes any difference on the pH if the solar cover is off or on. But I will keep that in mind as I test.
    SWG
    1.5 HP pump
    dmanb2b's Avatar
    Apr 2009
    NY
    3,728
    Re: SWG & pH
    Quote Originally Posted by frustratedpoolmom
    Off to the pool!
    Funny you should mention that FPM, I do....7.5 with cover off, 7.2 with solar cover on for more than 24hrs...I just attributed it to less outgassing with the cover on
    11,969
    Re: SWG & pH
    Yes, I believe that is the case.
