Thread: Pool filter issues when vacuuming
    When vacuuming my pool, everything works fine for about 10 minutes. After that, dirt comes from the return line back into the pool. The sand filter is working to some degree, as when I backflush it, the water is very dirty. It is not sand going into the pool. HELP...
    gresta46001
    21,000 gal IG Vinyl
    Hayward Pro Series Sand Filter
    1 HP 11/2" pump
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Pool filter issues when vacuuming
    You can open up the filter and check to see if the sand is channelled.
    Jul 2009
    Shawnee, Kansas
    92
    I have issues like this sometimes when the spider gasket in my multiport valve is not seated properly. I sometimes will get 'waste' water returning into the pool while I am vacuuming which spills dirt back into my pool.
    Matt
    20,000 gallon, sand filter, IG vinyl
    Thanks, I checked the spider gasket, and it needs replaced. That will probably fix the issue.
    gresta46001
    21,000 gal IG Vinyl
    1 HP 11/2" pump
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Is the filter pressure significantly higher when the dirty water starts returning to the pool? If so, here's a possibility: You start vacuuming with a clean filter and everything works like it should. As the filter gets dirty, the filter pressure rises, and a weak multiport gasket allows dirty water to bypass the filter and return directly to the pool.
    my pool has done the same thing all summer. i had to replace the pump and ever since i done that when i vacuum dirty water comes back through the jets. i stop and backwash and start again and it works fine for a while, then it the dirty water comes back through the jets again. how do i check to see if it is a bad multiport, or is this something i have to get a pool guy to come and do?
